for all of those with drops...
hey, does anybody in here have a regular cab f150 flare side dropped? if so, how much of a drop do you have and would you happen to have pictures?
thanks
-matt
thanks
-matt
Shackle/Hanger drop means that both ends of the rear leaf spings have been moved upward to facilitate the rear end getting lower. The quickest way to drop the rear is with 2" lowering shackles which are longer than the stock ones. I believe that JLP even makes these in a 3" size.
The hanger is what the leaf spring is mounted to near the cab side of your frame. Swapping these out will allow you to do the same thing with the front of the leaf spring that you can easily do in the rear. BUT...changing the hangers is not as easy as changing the shackles...MUCH MORE WORK involved.
Mine can be seen here with the hanger/shackle drop:
https://www.f150online.com/galleries....cfm?gnum=2864
Take a look
Here is the link to my gallery for you to have a look at the truck to give you and idea of what it will look like
Drew
https://www.f150online.com/galleries....cfm?gnum=3761
Drew
Re: Take a look
Drew
Drew
But, how's the ride quality? I know the 3''/4'' drop has really good ride quality, but I always wounder about the ride quality of a 4'' / 6'' drop!
