3in spindle lift ques.
i found a good deal on spindles for my 01' f150
and wondered if anyone has had problems with them.
they are fabtech spindles and i figured they would
bring the front end up so it doesn't look like the rear
is higher. I also keep ripping out the plastic wheel wells
when i bash the front end too hard in the desert. pics
would be great too. thanx
I have the 7 inch fabtech lift kit which uses the lift spindles and I assure you that you should have ZERO problems with it. Also you dont need to change shocks, you can keep your OEM or what ever ones you have on right now.
