Sponsored by: CARiD
going bigger question
Old Dec 26, 2003 | 12:14 AM
SOCALXJ's Avatar
i already have a 6" fabtech lift with a 3" body lift, running 37's.
well im used to it and want to go bigger... without dropping another gripp load again like the first time.
Ive seen that there are coil spacers that are made out there from 1" - 2.5" for the F150's.
Here's my question,
I've talked to Fabtech, and they are really hesistant to ever say, "YA! Go for it man" with changing up there components. They're really cautious that way(covering their ***'s).
Anyways, they said that the upper arm may not provide enough adjustability with the camber of the wheel if i go to big.. they said, a 1" spacer may be fine, but nothing bigger.
Anyone used a spacer with the fabtech lift?
If you have what size and how did it effect your truck?
What size tire did you run?
I want to get at least a 38 under it, cause i clear 37's no problem at all right now.
thanks for the info
Old Dec 26, 2003 | 08:30 AM
Captain_Nemo's Avatar
2wd or 4wd ?
Old Dec 26, 2003 | 12:07 PM
SOCALXJ's Avatar
2
Old Dec 28, 2003 | 01:55 PM
SOCALXJ's Avatar
this board is full of information.. wow
come awn its been 3 days and no info at all to share???
