Sponsored by: CARiD
Front end noise
Old Oct 25, 2003 | 02:47 PM
dekm's Avatar
Front end noise
I recently lifted my 2wd Supercrew with fabtech spindles and 2 leveling coils. When travelling down the road, especially at low speeds and i hit a bump, i hear a noise up front as if something is loose up front. I have removed the lifted and installed twice now, but the noise is still there. I have read in some other kits, that they use sway bar end links. Could this be my problem? Hope to get somekind of feedback here, if not the lift is coming off.
Derrick
Old Oct 25, 2003 | 11:07 PM
Rotties150's Avatar
Not that this would specifically apply to your situation....
I had a rattle / loose part in the rear of the truck when going over moderate sized bumps. Found it to be the Anti-sway bar that I had installed a while back...it was rattling against the gas tank shield. A bit of bending of the shield did the trick.
Also, up front...I had a loose shield / covering of the 4wd shaft. Just a matter of hunting it down and tightening it up.
Sorry I have no specifics on what might be the cause of your front end noise.
Good luck...
