Sponsored by: CARiD
Need help w/ part identification
Old Jun 7, 2001 | 01:22 PM
Justin93F150's Avatar
Exclamation Need help w/ part identification
I have a 93 F150 4.9L. The front right of the truck is lower than the left side. I first thought it was a bad spring. But a closer look reviled a bad bushing. I am not sure what it is called but it is a rubber bushing that is attached to a part that could be called a track locator bar (attached to spring perch and runs back to frame under the foot well of the truck). The bushing is sandwiched between the mounting point and the bar. What is this called (bar) and what is the bushing called? Is it hard to replace?
Thanks,
Justin (New!!!! Ford truck Owner)
Justin Grant
http://www.alexander-grant.com
Old Jun 7, 2001 | 05:51 PM
summitman's Avatar
Post
Justin,
Is the bushing you need in front of or in the rear of the arm? If you can tell me I can give you the part #.
98 f150 4.6 auto 4x4 supercab-short box/bright red & black/6 disk cd changer/ dynomax cat back/k&n fipk/super chip/lund taillight covers/factory fog lamps/Ford mud flaps/pace edwards box cover/ultra wheels/LT265-75-16 BFG/ westin nerf bars/steel horse billit grill & bumper insert/reflex shocks/bosch plat. plus 4/accel wires/auto start/left hand grab handle/2001 lighting headlamp and corner lights/2002 Ski-Doo Summit 800 High Mark X
Old Jun 7, 2001 | 08:45 PM
Post
<font face="Verdana, Arial" size="2">Originally posted by summitman:
Justin,
</font>
The bushing is in front towards to front of the truck.
Thanks,
Justin
Old Jun 8, 2001 | 10:04 AM
summitman's Avatar
Post
the bushing you need is attached at the foot well of the truck correct? If this is correct I need to know some things---
4x2 or 4x4
build date
where the truck was built
if you dont know just give me the vin #
Old Jun 8, 2001 | 03:31 PM
Post
4x2 or 4x4
build date
</font>
It was built in 06/93 it is a 2WD. Not sure of the BUILD LOCATION. VIN is 1F1EF15Y5PLB04856.
Thanks,
Justin
Old Jun 8, 2001 | 07:39 PM
summitman's Avatar
Post
there are 2 bushings per side--
left-D9TZ-3B203-A
-F2TZ-3B203-A
right-D9TZ-3B203-A
-F1TZ-3B203-A
hope this helps-fairly good install-you may have the drill some rivits-just replace them with bolts when you put it all back together.
Good Luck
Old Jun 8, 2001 | 09:58 PM
Post
left-D9TZ-3B203-A
-F2TZ-3B203-A
right-D9TZ-3B203-A
-F1TZ-3B203-A
Good Luck
</font>
Thanks for the help!
