Suspension vs. Body? I need opinions!
I have been thinking of adding a lift to my 01' SuperCab 4x4. Besides the cost, what is the difference between a suspension and body lift?
I mean, I know the difference but what effects will it have on my truck. Is 3 inches of body the same as 3 inches of suspension?
I saw this POS Dodge Ram the other day and I don't want my truck to look like his. You could tell it was cheap lift. Like 4 blocks between the axle and leaf springs. Dodge makes those trucks abnormally high and stupid looking in the first place.
Any susgestions as to what to use or what to go for?
bIGGINS
My New Ride->>
2001 F-150XLT 4X4 Sport SuperCab
Styleside, Short Bed, Black on Black, 4R70W, 5.4L, 3.55reg, 17in Rubber, OEM Snapless Tonneau Cover, Harley Bedliner
Add On's
Sony CDX-M770 Head Unit, (2) JLAudio 8W6's, RF Punch 150 amp, HL Blackouts, DashMiser Plus II Strobe Light (fireman)
My Last Ride->>
1999 F-150XLT 4X4 Reg Cab
Styleside, Long Bed, Amazon Green, 4R70W, 4.2L V6, 3.55reg, 16in Bridgestone Duelers, OEM Snapless Tonneau Cover
bIGGINS
My New Ride->>
Add On's
My Last Ride->>
A body lift will lift only the body of your truck. A suspension lift will raise the whole thing. Think of it this way. If you have a suspension lift, you will get 3 more inches of ground clearance underneath the whole truck. If you get a body lift, the body of the truck will be raised, but the frame will still be in the same place, resulting in more axle clearance, this is why you can see the frame hanging out from under trucks with body lifts. If you have money to do it, get a suspension lift, but they run from $1000 - $2500 just for the lift. If you just want to add larger tires, a body lift is the way to go. You can put a 3" body lift on there and fit 33"s easy. If you want performance, (smoother ride, offroad performance) then your best bet is the suspension lift. Hope this helps, good luck.
1999 super cab
white with tan bottom
4x2 automatic
4.6L v8
BFG AT TA KO 265/75
WAAG grillguard
2 KC daylighters
vampire remote start combo alarm
steelhorse nerf bars
Husky chrome toolbox
4 pioneer 3 way 6x8's
wants: 2 chamber flowmaster dual exhaust
tan fender flares
american racing atlas
2" fabtech suspension leveling kit
1999 super cab
4x2 automatic
4.6L v8
BFG AT TA KO 265/75
WAAG grillguard
2 KC daylighters
tan fender flares
I agree with everything trucklover said except that suspension lifts give you more clearance. This is not always true. Several people i know have the 4" rancho suspension on their trucks with 35" tires. I have a 3" body with 35" tires. The clearance in the front is the same (skidplates same height above ground and such) except increased by a tire height change. This is because a suspension lift retains all the stock angles the same as stock in the suspension. More or less you can think of the two in that a suspension will give you improved articulation in the suspension even though you've added bigger tires. A body lift will not have as much articulation because the suspension has not changed, therefore, rubbing and such are more frequent. Although i have a 3" body, i can still get quite a bit of flex out of the front and rear suspension, but my friends with the rancho's can get more. Clearance is increased under the truck however, which is what trucklover is probably talking about. anyways, hope this helps.
-Brandon Warford
97 F150 4x4 Sport Brt. Red SuperCab
4.6l Triton V8
3.55LS Rear-end
MECHANICAL MODS:
Custom Alum. Skidplate
3" Performance Acc. Body Lift & lift lips
1-1.5" torsion bar
Fabtech 4" Blocks to replace stock
Clear Corner Lenses
315/75R16 Yoko. Geolander MTs
American Racing Atlas 16x10
True Dual Exhaust
--(2) 3 Chamber Flowmasters (Exits like the Lightning)
FUN MODS:
Pioneer 8000 3D series
Boston Acoustic 5x7s
Sony Xplode 4ch Amp
(2) 8" RF XLC Subs
Custom 4x4 Sticker
Viper Alarm
FUTURE MODS:
4.56 gears
Repaint around Headlights where clearcoat is coming off >=(
Fix ding in tailgate
New pinstripe
Heckethorn or Rancho Steering Stabilizer
Rancho RS9000 Shocks & Control System
Thats about it for now!
Check out my NEW WEBSITE:
****BigBadRed's Website****
Killintime4fun@aol.com
"F-150: The other woman!"
"...the road curves to the right and there are a lot of signs that say you cannot turn left...TURN LEFT."
-Brandon Warford
4.6l Triton V8
3.55LS Rear-end
MECHANICAL MODS:
1-1.5" torsion bar
Clear Corner Lenses
True Dual Exhaust
FUN MODS:
Sony Xplode 4ch Amp
(2) 8" RF XLC Subs
Custom 4x4 Sticker
Viper Alarm
FUTURE MODS:
4.56 gears
New pinstripe
