Sponsored by: CARiD
spindle choice???
Old May 7, 2001 | 07:33 PM
bluefish97's Avatar
Question spindle choice???
Ok guys, the tax check finally came in so now it is time for the new spindles. Should I spend the few extra dollars on the Fabtech or should I go with Procomp? Do you really get what you pay for? The 3" lift from Fabtech looks good cause I can keep the stock wheels since there is no offset problem. I don't really off road much, just need bigger tires for the boat ramps. Some of these ramps are mud and sand. I have read a lot about this in the past, but I heard that Fabtech just recently had a problem with bearing slipping on the shaft. Any advice would be appreciated. I plan on ordering this week. Bluefish
'97 F150 XLT SC 4X2 4.6L Moonlight Blue Century Cap 265/75/16 Firestone Wilderness A/T
Old May 7, 2001 | 09:22 PM
crazedf1's Avatar
Post
hey blue what wheels do you have? i was wondering because the shops around here have said i would probley need new ones, and being a full-time student and a part-time worker means there is not alot of truck money left after bills. so if you could tell me what wheels you have i would appreaceate it.
2000 4.2l V-6 w/sport package std. cab. 2wd, bright red
billet grille
clear corners
herculiner bed liner
k&n filter
sony head unit
two 10" kicker comps.
sony amp
viper alarm
future:
spindle lift
fipk
chip
headers
exhaust
Old May 9, 2001 | 07:05 AM
bluefish97's Avatar
Post
hey crazed, I have the stock 6 spoke wheel. It is the one that has 3 double spokes with a center cap covering the nuts. Bluefish looks sorta like the blue supercab with the gray stripe at the top of the page. I was told that with Fabtech, the 3" spindle lift could use the stock wheels but the 3.5" lift with the coil springs needs new wheels with the proper backspacing. Hope this helps. Bluefish
Old May 9, 2001 | 07:15 AM
DANIEL FINE's Avatar
Post
[QUOTE]Originally posted by bluefish97:
bluefish97 I have the Fabtech 3.5 in lift spindles on my truck the ride is great and it looks good, don't know about the Pro Comp lift. dan
Old May 11, 2001 | 08:09 PM
crazedf1's Avatar
Post
thanks alot. are all the ford rims have the same backspacing
