Sponsored by: CARiD
leaning to the right
Old Apr 25, 2001 | 11:13 AM
patrickjp's Avatar
Post leaning to the right
my truck appears to be "leaning" to the right, does torsion bar adjustment fix this?
thanks
Old Apr 25, 2001 | 02:01 PM
JSL1414's Avatar
Post
If your truck is 4x4, the torsion bar adjustment should fix it.
*White 97 F-150 Supercab XLT 2WD
*4.6L Triton V8
3.55's
*Fabtech 2" Leveling Kit with Fabtech A-Arms. *1.5"rear blocks
*SuperLift 3 inch BodyLift
*315/75/16 Kelly Wild Spirts
*American Racing AR136
16x8
*Flow Master True Duel
40 series
*Rhino Liner
*K&N Filter
*Smitty Built Brush Guard
*Magellan GPS Navigation
*Lund Wind Visors Bug Deflector
*Kenwood Deck Punch Amp
*2 JL W-6 10's
*2 KC Daylighters and
*2 Procomp Stainless Steel
WISH LIST:
*3.5 Fabtech Lift Spindles
*4.10's
*BETTER BRAKES
Old Apr 25, 2001 | 05:11 PM
sigalph's Avatar
Talking
If it is under warenty take it to the dealer and have them do it for free.
Regards,
Sean
2000 F150 XLT 4x4 Extended Cab
Deep Wedgewood Blue, 4.6L Manual Trans, Ford Tonneau Cover, Magnum Bug Deflector, Panther 16x8 wheels with 285/75 R16 BFG All Terrain T/A , 'Superchips' Performance Chip, K&N FIPK, Westin Side Bars (Black), 3" Jardine Cat-Back Exhaust with Stainless Tip, Clear Corners, Tinted Font Side Windows
Old Apr 26, 2001 | 12:20 AM
DGreen's Avatar
Post
What exactly do you mean? Do you mean your truck is lop sided...because mine is. About 1 inch lower on the driver's side...you can see it when you look at the truck directly from the front or back...
let me know if this is what you see on your truck too, because I can't figure it out!
2000 F150 XLT 4.6L V8 Auto, SuperCab, Torreador Red Metallic, Magnaflow Cat-Back Exhaust, K&N Drop-in, Ford Bedliner, Tinted Windows, Steel Horse Billet Grill, Fabtech 3.5" Spindles, 1.5" rear blocks, 3" Body Lift, Lift Lips, 33/12.50/16.5 BFG AT's on 16.5x9.75 American Eagle 589's, Fabtech Performance Shocks, Sylvania Cool Blue Headlights
www.geocities.com/y2kf150
Old Apr 26, 2001 | 09:07 AM
patrickjp's Avatar
Post
dgreen,
yep, a little lop sided.. the more I look at it, the more it seems to be from the cab-back. Like the Bed is a little lop sided.. kinda strange but this truck is well outta warranty, just thought I may be able to even it out myself
hmmm
97 F150 XLT: Two-Tone Green and Tan, V6 4.2L Auto Trans 4X4, 3.55 gears, 265/75/16 Dueler AT's, Edelbrock Performer IAS Shocks
MODS:Airaid FIPK, Superchip, Ravin Z55 Exhaust SI/SO
GOODIES:Kameleon Head Unit w/12 disk cd changer, JVC 4ch 560watt poweramp, Bazooka Tube, Boston Acoustic 5x9's, Tinted Back, Westin Nerf Bars..
Old Apr 26, 2001 | 11:16 AM
Matt90GT's Avatar
Post
measure!
First inflate all the tires to the same PSI. this should be common sense, but make sure all tires are the same size!
Then measure the rear height thru the center of the wheels to the bottom of the wheel well. Try to get in the center of it. Write it all down. Then do the same for the fronts. Figure out where you are at.
You can adjust the fronts with the torsion bars.
Other things to check is for broken or crushed body mounts!
Old Apr 26, 2001 | 05:09 PM
Black Truck's Avatar
Post
My truck was leaning to the left when I bought it. The dealer adjusted the torsion bars and leveled it. The mechanic said the bars have differnt settings for different size tires.
97 150 SC 4x4, 4.6, 3.55, 265/75R16, 1st Ford truck; bought 4-00 with 55500 miles
Added: Ford running boards, Ford molded mud guards (f&r), Class IV receiver, Delta Truk Pockit toolbox, Dupli-Color roll-on liner on bed front & sides, Bed mat, Ventshade Stepshields
Old Apr 26, 2001 | 06:27 PM
MechE's Avatar
Post
They only thing I've ever heard of is its spring fatigue. They have a TSB for ford rangers with the same problem. Ive never seen one for f150s though. Basically one set of rear springs wears out faster than the other and it sits lop sided
Old Apr 27, 2001 | 12:06 AM
MrScot's Avatar
Post
Mine leans to the passenger side. From talking to several people, there F150's do it as well. Many beleive it's a design for the truck to compensate for wieght from the driver and a full gas tank. Anyone else heard of this?
S.
Old Apr 27, 2001 | 02:33 AM
JimW's Avatar
Post
My truck was the same way. The Rightr rear was noticeably lower. I carefully measured each end to the top of the fenderwells, and it was about 3/4" lower. I noticed that spring pack was sitting a bit lower to the overload spring. The right front was about 1/2 inch lower. I got custom add-a-leafs added between the first and second spring in the back. The result, about 1.5 inches lift at the rear fenders. It almost completely leveled out the truck in the back! I then adjusted the torsion bars. The result is now that my truck sits within 3/16" of being even left to right on both front and rear. Close enough for me! The extra leafs really boosted my sagging fanny!
'97 F-150 4x4 SC SB 4.6L. Riding on Sport King 265/75R16 AT's. Add-a-Leafs & Torsion lift. Side Bars. WMS Intake, TB spacer, and Superchip!
Wish list: 4.10 Gears, Hedman Hedders, 3" body lift, 33x12.5 MT's!!
