Sponsored by: CARiD
Do I need the Shock boots?
Old Apr 7, 2001 | 07:18 PM
FamilyRide's Avatar
Arrow
If you do off roading, you might be better of without them.
I've heard the same thing that they end up packed with mud and crud.
2000 EDDIE BAUER EXPEDITION 4x2
  • Estate Green
  • 5.4 ltr
  • 3:55 LS rear
  • Superchip!
  • Airaid FIPK
  • Gibson S/S Swept Side Cat Back Exhaust
  • Hellwig Rear Anti-Sway Bar
  • Edelbrock Performer IAS Shocks
  • Xenon Super White Head and Driving Lights
  • Clear Corners (installed then removed and reinstalled OEM's)
  • Tow Package
  • Rear Load Leveling
  • Moonroof
  • Century Child Seat!
  • Front Polyurethane Anti-Sway Bar Bushings recieved, wrong part number
-->Come share my Addiction<--
Old Apr 7, 2001 | 10:50 PM
ilmagill's Avatar
Post
So its not really a necessity that I have them. I was just worried that exposing the shaft might cause it to get dust and other things al over it, causing it to prematurly break.
Old Apr 7, 2001 | 10:52 PM
JonC's Avatar
Post
I noticed you had different shocks installed up front than in back... any particular reason?
Thanks!
Old Apr 7, 2001 | 11:05 PM
ilmagill's Avatar
Post
Well I first ordered just 4 rancho rsx shocks...they ordered 2 longer ones in the front for the spacers...but when they came in they were too long...but they had a set of procomps that apparently matched the increase ion height so they installed those.
Old Apr 8, 2001 | 12:06 AM
ilmagill's Avatar
Post Do I need the Shock boots?
I just got my truck back from 4wheel parts....1.5 inch daystar polyeurethane spacers and 2 procomp es3000 up front and 2 rancho rsx's in the back. And none of the shocks have the shock boot....is this a bad thing, will it lower the life of the shock?
Things to come:4.10 gears, Grill
ilmagill@aol.com For Pictures :
www.geocities.com/ilmagill
Old Apr 8, 2001 | 12:18 AM
Howies_effie's Avatar
Post
I was told that the boots actually cause more trouble than they prevent - they trap mud and crud inside them and cause the rod and seals to wear faster.
On the other hand, they prevent rocks and sand from pitting the rods. It's a tradeoff I guess. I have seen race trucks set up with no boots and little flat plastic guards that prevent rocks hitting the rods. Sorry I don't have any pics of this but I could dig some up if you want.
Howie's Effie
Amazon Green 2000 F150 XLT 5.4L 4x4 ORP Supercab Flareside
Captains Chairs, Electronic Shift, Rear Slider, Keyless Entry, Cab Steps, 3.55 L/S
Mods: Superchip, WMS Velocity Tube, Flowmaster Force II, Scorpion Spray in Liner, fogs + hibeams (thanks FedExPilot)
Old Apr 8, 2001 | 05:00 PM
ilmagill's Avatar
Post
Never mind, I went and checked out the truck and its 4 Procomp Es3000's. That makes a bit more sense.
Old Apr 8, 2001 | 07:34 PM
G Patricio's Avatar
Post
ilmagill,
Make sure you didn't pay for the Rancho RSX's because they cost a little more than double the es3000's.
Also, just wondering if you measured before and after to see if the spacers gave you 1 1/2 inches? I ordered their one inch spacers (still awaiting) and was curious if that was accurate.
Old Apr 8, 2001 | 07:45 PM
ilmagill's Avatar
Post
Yeah they gave me the rebate on them. Thanks. I'm not exactly sure what size spacers I got...but they gave 1.5 inches of lift. They look to be about 2 inches thick but the coil sits partially inside so im not sure exactly how much spacer it sits on top of. I believe 1 inch spacers give you a bit more than 1 inch of lift. My truck sits very slighty higher in the back....maybe less than .25 inches. Its 38.75 inches to the top of the front fender and 39 inches to the top of the back fender.
[This message has been edited by ilmagill (edited 04-08-2001).]
