Sponsored by: CARiD
1" drop for the front
Old Mar 27, 2001 | 09:32 PM
F1504u2nv's Avatar
Lightbulb 1" drop for the front
Hey,
Does anyone know where to get front springs for a 99 F150 2wd that would only lower it an inch. Most of the kits and springs ive found only offer 2 and up drops for the front. Any help would be great,
thanks
'99 F150 XL SC Shortbed, Silver, KN Filter, Flowmaster exhaust w/ Lightning exhaust tips on pass. side in front of rear tire, Superchip. 285-60-18 Falken's on 18" Lighting Rims, Lightning emblems, Superwhite headlights. Kenwood Mask cd player, Cerwin Vega 3way speakers, 1 MTX 12" Subwoofer
Old Mar 27, 2001 | 09:58 PM
BluOvalOK's Avatar
Post
Try (eibach.com). Just ordered a set for my Expedition. $65.00 for the front 2 springs. I thing it is 1.5" tho'.
'97 Expy 4.6L, 2wd XLT, Airaid Intake
Rancho 5000
Superchip
Ravin Z-77 Exhaust
Raybestos Ceramic Brake Pads
Old Mar 27, 2001 | 10:11 PM
F1504u2nv's Avatar
Post
thanks ill take a look but are you gonna need shocks with those or will the stock ones work
Old Mar 27, 2001 | 10:22 PM
BluOvalOK's Avatar
Post
I already have the Rancho 5000 series shocks, but am considering the Bilstein's. I was told that replacing the shocks when you do the springs is a good idea, since you are already in there.
Keep in mind that you will need to have the front end re-aligned as soon as you finish the springs.
Rancho 5000
Superchip
Ravin Z-77 Exhaust
Old Mar 27, 2001 | 10:23 PM
F1504u2nv's Avatar
Post
yea i was thinking of some bilstiens too, thanks for the help.
Old Mar 29, 2001 | 04:25 PM
RayC's Avatar
Post
eibach has a few different spring applications depending on if you have a v6 or v8 or reg. or ext. cab truck ...
reg cab v6 - .75"
v8 - 1.3"
- 2"
ext cab v6 - 1" #3575.520
v8 - 1.5" #3575.520
- 2.5" #3576.520
springs for v6 and v8 are the same for the coresponding drop, but give different heights so you could use the v8-2.5" spring on the v6 and probably get a 2" drop
eibach also has an alignment kit/bolt #5.87385K -- which will make it much more easier for the shop to perform an alignment ( larger area to adjust )
98 F150 SuperCab XL
4.2L V6, auto, 4x2
K&N Filtercharger
APC clear corners APC clear tailights
Belltech 2" shackles
Extang soft tonneau
ArmourThane sprayed liner
Cloudrider grille screen
DynoMax exhaust
Panasonic CD tuner
12" JL sub
Clarion 5x7 3-ways
Rockford Fosgate amp
Soon ...
new exhaust system
-DynoMax looks bad
lowered suspension
