Add-a-leafs
I'm looking for a set of 2" or higher add-a-leafs. I've found some at jcwhitney and carparts.com I'm wondering if anyone knows of any place else that would have them.
1997 F-150 Lariat
Ext Cab Short Box
4x4 Off Road Package
3.55 Gears
265/75 R16 Uniroyal Laredo M/Ts
My 2 cents worth
If you're gonna stroke it, POWERSTROKE IT!!!
http://www.powerstroke73.homestead.com/
1997 F-150 Lariat
Ext Cab Short Box
3.55 Gears
My 2 cents worth
I'll sell you the ones that came with my lift. I used them about a month and then changed to lift blocks. I think they are 2.5" lift.
Let me know if your interested.
Scott
97 F-150 Black, 4x4 XLT ext.cab,sb,w/Offroad Package,
4" Suspension lift, 3" body lift,
4.56 gears w/LS,
Flowmaster 50 Series w/ duals out rear,
36x14.5x16 Parnelli Jones Dirt Grip tires,
16x10 Weld Sidewinder wheels,
Pre-Runner Bumper w/KC Daylighters & PIAA 520 Driving Lights,
Steel Horse Billet Upper and Lower Grilles,
Kodiak Sidewinder Steps,
Pro-Comp Front Skid Plate,
Summit Aluminum Diff cover,
Rancho 9000's w/in-cab remote,
Lift Lips,
Lighted FORD logo,
K&N Filter,
Superchip,
Bosch Platinum +4,
TransGo Shift kit,
Clear corner lenses,
Altezza style Tailight covers,
Bug shield,Tinted windows
Sony ES Mobile head unit,Sony ES Mobile changer,MTX Thunderform sub,Boston Acoustic Pro-Series up front, Polk in rear,PPI & Coustic Amps,Alpine Alarm
Check it out at:
http://hometown.aol.com/squanto804/scottwebpage.html
<A HREF="http://www.f150world.com/Squanto804" TARGET=_blank>
http://www.f150world.com/squanto804</A>
Scott
4.56 gears w/LS,
Lift Lips,
Lighted FORD logo,
K&N Filter,
Superchip,
Bosch Platinum +4,
TransGo Shift kit,
Check it out at:
Squanto,
What made you decide to switch from the add-a-leafs to lift blocks? At some point I plan to do a 4" suspension lift and was leaning toward a kit with leafs instead of blocks. Just curious.
Oh, yeah. How do you like the Dirt Grips?
98 F-150 XLT 4X4 ORP Super Cab Short Bed, 4.6, Auto, 4.10's, Mag-Hytec diff. cover, Magnacharger supercharger, K&N FIPK, Superchip, Gibson single cat-back, 80/100w German head lamps, 80w amber fog lamps, Warn HS9500i winch with semi hidden mount, Wrangler dual battery kit with red & yellow top Optima batteries, 285/75R16 Goodyear MT/R's, 16x8 Center Line Hell Cats (JUNK WHEELS), Rancho RSX shocks, B&M deep aluminum trans pan, Rhino bedliner. Needs one more door.
http://hometown.aol.com/ninetyeightfword
[This message has been edited by 98fword (edited 03-21-2001).]
How much do you want for them and what kinda are they? Also did they give you 2 1/2" of lift or are they "supposed" to give you 2 1/2" of lift. I've seen some 2" ones that would only give you 1" of lift. You might have to hold onto them for a while. I have to wait until spring field work starts before I will have enough money to buy them.
I got add-a-leafs with my lift kit. they were supposed to lift the rear 4" but for some reason it only went up 1.5" so i had to add 2" blocks just to get the truck level. Just a warning that the leafs may not work as well as advertised.
-Jon
-Jon
98fword, I switched to blocks because I thought the addaleafs made the ride much rougher. I wanted more of a stock ride. I also like the rear a bit higher, like it is stock, and the add a leafs evened it out. At some point, I'm taking out the blocks and installing new rearched springs just because I'm not a fan of blocks for saftey reasons.I love the Dirt Grips, best big tire out there,IMO.
Powerstroke, They are from Trailmaster and I think they are 2.5". When they were on my truck, they sat the rear even with the front.
Scott
Scott
There is an article under the "Product Reviews" on the add-a-leafs. It has a detailed description of install, I think the guy got them from Summit for $50.
Yeah, it depends alot on the brand of add-a-leafs you get and how stiff your current leafs are. I don't think I've ever seen an add-a-leaf lift a truck exactly how much it says that it will. I'm actually counting on this. I only want about 1 to 2" of lift from this.
