Sponsored by: CARiD
just wondering
Old Mar 17, 2001 | 11:33 PM
JDm's Avatar
JDm
Post just wondering
If i ever do sell my truck and buy a 4x4, What size lift would be needed to fit some 35x15.50r16.5 on 16.5x12 inch wheels? could i fit it with something like the 5inch rcd lift with the torsion bars cranked up an inch or so.
Old Mar 18, 2001 | 01:20 AM
y2kboti's Avatar
Exclamation
You'll need to add a 3in body lift on top of the suspension lift to eliminate any rubbing.
2000z71 7-8in Superlift 3/4 ton torsion bars, 3in PA body lift, CST rear dual shock kit w/ Rancho 9000s, 35in BF Muds and tons of other cool mods!
www.geocities.com/y2kboti
IN MEMORY OF DALE EARNHARDT
Old Mar 18, 2001 | 09:32 AM
ccla's Avatar
Post
I Think y2kboti is a little off. On F150 4x4's all you need to run 35's is the 3" body lift. Not in addition to the 5" suspension lift. There are quite a few guys here running that setup
Old Mar 18, 2001 | 10:03 AM
Matt90GT's Avatar
Post
With a 3" body lift or 4" suspension lift you can run 35x12.50 tires.
With the wider 15.50 tires there, you will need some fender trimming in the front on the bumper. But should fit.
Old Mar 18, 2001 | 11:19 AM
JDm's Avatar
JDm
Post
Matt90GT,
to run 35x12.50's all you need is a 4inch suspension lift( procomp,trailmaster,rancho...). My queston is if you started with the rcd 5inch suspension lift and then cranked the torsion bar another 1-2 inches could you fit the 35x15.50r16.5. It seems that if with 4inches of lift 35x12.50 will fit, then with 6-7inches of lift the 35x15.50 would be fine.
Correct me if im wrong but that makes since right.
[This message has been edited by JDm (edited 03-18-2001).]
Old Mar 18, 2001 | 11:39 AM
HOSRACN's Avatar
Post
You can fit the 35's alright, but when you put anything on over 33's, especially 15.50, you run the risk of screwing up your axle. There is too much rubber on the ground. You should think about a straight-axle conversion for that set up.
Old Mar 18, 2001 | 01:49 PM
y2kboti's Avatar
Exclamation
I'm not guessing. A guy I know has a 5in Superlift and a 3in body lift and under full compression his tires rub. He is running 36x14.5 M/T.
Old Mar 18, 2001 | 11:06 PM
BIG_D_98's Avatar
Lightbulb
JDm,
I have a 5" RCD and a 3" PA body lift. My 315's fit fine. No rubbing whatsoever.
I can't see anyway you can fit 12" wide wheels. My 16x10 w/4.5" backspacing have less than 1/2" clearance from spindle. That and there is roughly 2" clearance from A-arms in full turn with 315's.
'98 Ford F-150 S/C ORP
4.6L, 3.55LS, AT,
Teal with silver two-tone
Delta Flow 40-Series Flowmaster with dual rear exit, Hypertech Power Programmer, Clear Corners, Clear Taillights(before ticket), AirForce One FIPK, Superwhite head and fog lights, Billet Grille w/ bumper insert, Lighted Logo on grille, Westin PCS nerf bars, Granatelli MAS, JL Audio Stealthbox w/ two 8's, Pioneer 3-way 6x9's, two Kicker Amps
4.10LS, 5" RCD lift, 3" Performance Accessories body lift, Gap Guards, Chrome Traction Bars (Rancho), 16x10 Eagle 1439's, 315-75/16 Pro Comp A/T
http://albums.photopoint.com/j/AlbumIndex?u=1434673&a=10754263
Old Mar 19, 2001 | 01:25 AM
mudder's Avatar
Post
15.50's are just too wide for a truck that is driven every day anyway. They don't look very good either. 14.5 is plenty big.
Patrick aka Mudder or MR.Daylighter of Arlington Texas (D/FW), member of the Texas Chapter club DAYLIGHTER edition F150 ®, Black 98 S/S S/C F150 4x4 0RP 5.4 V8 3.55ls, 4" Rancho suspension lift with RS 5000 shocks, Ramsey Pro 8000 hidden winch, Grizzly roll bar, Superwhite Bulbs, 2 Baja back up lights, 2 KC 57 Series 5x7 100 watt long range lights, 2 KC 55 watt fog lights (all-season kit) 10 165 watt KC Daylighters, 2 chrome, 4 Stainless, 4 black ( with 14 KC's, I come alive at night), Manik grill guard, Westin step bars, Rhino Taillight guards, Magnum bug shield, Sonic aluminum treadplate 36" tool box, Flowmaster 40 series dual exhaust, Airaid High Flow system, Lighted Ford logo on tailgate, 285/75/16 BFG AT/S KO, American Racing Baja wheels, Pro Comp headlight blackouts, Red Top Optima battery, personalized plates, Cobra 18WXST CB radio with 3' whip antenna, Escort Laser/Radar detector, Nokia cell phone, a Mobil Speed Pass on the back window, 3 F150World stickers, a Texas Chapter of F150World.com sticker, a BIG KC block sticker on the back window and a DAYLIGHTER sticker on the front windshield, and yes, I also have been infected with the infamous door crack. More to come for the Daylighter: JBA headers, superchip, 1 more Daylighter for the front, 2 KC reverse Lights, PIAA fog lights to match head lights, tint, BFG 295 AT/s. If you would like to see pics, email me at Mudder@TexasChapter.com
Also the Moderator of the Ford Trucks vs. GM trucks and Ford trucks forum over on fordvschevy.com so check it out.
2 BRT 4U "Go ahead, flash your brights at me, see what will happen."
Got light?
It's a KC thing.....you wouldn't understand.
Candlepower to date: 4,214,000. Gonna add more soon.
See all my pics at my zing.com site: http://www.zing.com/album/?id=4294059243
Also check out www.F150World.com/Mudder
