Sponsored by: CARiD
Driveline Vibration
Old Feb 22, 2001 | 06:51 PM
Ford4ever's Avatar
Post Driveline Vibration
I was just reading at ring-pinion.com that when you lift a truck it changes the angles in of the u-joints and when you go to a lower gear ratio it causes vibration due to the driveshaft spinning at higher rpm. Has anyone experianced this with a 4" susp. lift? I am especially worried about the angles in my '92 2wd f-150 because it has 2 smaller driveshafts that connect to the body in the middle. This means that when i lift it the rear driveshaft will have a really steep angle on it.
Old Feb 22, 2001 | 08:52 PM
Y2K 7700 4x4's Avatar
Post
You simply rotate the input side of the axles up -- and tip the engine/transmission down. There are many articles on the subject -- and the angles are critical to component life and driver comfort.
Y2K™ Jim - N8JG@Hotmail.com
Toreador Red, Keyless XLT SC SB 5.4L E4x4 4wDisc/ABS, 3.73LS, Skid, HD 7700# Towing, LT-245's on Chrome, Tube-Steps, Captain's, 6CD, Tonneau, named: "Nick"
