Sponsored by: CARiD
RCD LIFTS?
Old Feb 19, 2001 | 12:38 AM
Rhyno's Avatar
Question RCD LIFTS?
All you guys with the RCD 5" lift, what is the biggest size tires you could fit by cranking the torsion bars. I know 35X12.50 tires fit with just the lift but I want to know if you could fit 36X14.50 tires by cranking the T bars. More replies the better, Thanks
Old Feb 19, 2001 | 10:32 PM
BIG_D_98's Avatar
Cool
Hey Rhyno,
I don't understand even wanting to crank the torsion bars if your truck sits level without it. I'm sure the 36's would fit, but they will rub. 100% sure. My 315's rub when near full turn. They don't rub so bad, that I can't do a full turn though. If you want tall, stay fairly narrow.
My next (extra) set will be 37x12.50 SSR's, or the new Pro Comp 37x13.50 "Extreme Traction" (when available)
'98 Ford F-150 S/C ORP
4.6L, 3.55LS, AT,
Teal with silver two-tone
Delta Flow 40-Series Flowmaster with dual rear exit, Hypertech Power Programmer, Clear Corners, Clear Taillights(before ticket), AirForce One FIPK, Superwhite head and fog lights, Billet Grille w/ bumper insert, Lighted Logo on grille, Westin PCS nerf bars, Granatelli MAS, JL Audio Stealthbox w/ two 8's, Pioneer 3-way 6x9's, two Kicker Amps
4.10LS, 5" RCD lift, 3" Performance Accessories 3" body lift, Gap Guards, Chrome Traction Bars (Rancho), 16x10 Eagle 1439's, 315-75/16 Pro Comp A/T
http://albums.photopoint.com/j/AlbumIndex?u=1434673&a=10754263
Old Feb 20, 2001 | 05:24 PM
Rhyno's Avatar
Question
Big D 98
How are you going to fit 37" tires when your 35" tires rub?
Old Feb 21, 2001 | 12:33 AM
BIG_D_98's Avatar
Post
Rhyno,
I think they rub now because of width, not height. This would make the 37x12.50's be about the same as now. In fact, I think the SSR's are a little narrower then the tires I have now. The 37x13.50's would probably need some trimming. I haven't really seen what they are rubbing on. I will figure that out when I get time to cut my frame back, install chromed tow hooks, and trac bars.
4.6L, 3.55LS, AT,
