Torque specs for cab & bed mounts with 3" body lift?
Well I finally got the chance to work on the P.A. 3" body lift. I'm to the point where the the bed and cab bolts are loosened. Can anyone tell me the torque rating on the body and bed mounts? I talked to the local Ford service rep and he told me:
cab= 60 ft. pounds
bed= 50 ft. pounds
Is this correct? It seems alittle low. Thanks.
Bill
1999 F250 LD S/C XLT 4x4
5.4L, 3.73, 4R100 trans.
Flowmaster 40 "DF" series, K&N, Superchip, WMS Velocity Tube, Rancho RSX shocks, Hellwig rear swaybar, Stull billet grille, 2-PIAA Pro80XT's (120W), 2-KC Daylighters (150W)
265/70 R17 BFG AT KO's on 17x8 American Racing Atlas rims
Kenwood 7007 CD, Alpine 3342 Signal Processor, Alpine MRV-F353 5Ch. Amp, Pioneer TS-A6865 3-way speakers, MTX Thunderforms. CompuStar alarm/autostart. On the way: Performance Accessories 3" body lift, 33/12.5/17 ProComps, GSP grille guard or PIAA airdam.
cab= 60 ft. pounds
bed= 50 ft. pounds
Bill
Not sure of the torque # , but I know that I just used Loctite and snugged them down real good. None have loosened up in over a year.
97 F-150 Black, 4x4 XLT ext.cab,sb,w/Offroad Package,
4" Suspension lift, 3" body lift,
4.56 gears w/LS,
Flowmaster 50 Series w/ duals out rear,
36x14.5x16 Parnelli Jones Dirt Grip tires,
16x10 Eagle Alloys 589 wheels,
Pre-Runner Bumper w/KC Daylighters,Steel Horse Billet Upper and Lower Grilles,
Kodiak Sidewinder Steps,
Pro-Comp Front Skid Plate,
Summit Aluminum Diff cover,
Rancho 9000's and remote,
Lift Lips,
Lighted FORD logo,
K&N Filter,
Superchip,
Bosch Platinum +4,
TransGo Shift kit,
Clear corner lenses,
Altezza style Tailight covers,
Bug shield,Tinted windows
Sony ES Mobile head unit,Sony ES Mobile changer,MTX Thunderform sub,Boston Acoustic Pro-Series up front, Polk in rear,PPI & Coustic Amps,Alpine Alarm
Check it out at:
http://hometown.aol.com/squanto804/scottwebpage.html
4.56 gears w/LS,
Lift Lips,
Lighted FORD logo,
K&N Filter,
Superchip,
Bosch Platinum +4,
TransGo Shift kit,
Check it out at:
Thanks Squanto,
Maybe you can answer another question for me. I notice after installing the steering extension, it has some play in it. Even though the bolt is fully tightened. I remember a few had this problem. Is there a fix for this?
I did torque mine the same way Squanto did.
As for the steering column extension I had to work with it a couple of times before finally having it tight and making no noises. It may look like it is well tighten but it help doing it over again.
My Ride: 1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications:
Split Fire Spark Plugs
K&N FIPK
Gibson Supertruck Exhaust System
Stepshield door sill protectors
Performance Accesories 3" Body Lift
Superlift 3" lift blocks
Performance Lift Lips
Gabriel Gas Ryder LT VST Shocks
Daystar Front Anti-sway Bar Polyurethane Bushings
Heckethorn Steering Stabilizer
35x12.5R16.5LT BFG All Terrain KO's
16.5x9.75 American Eagle 589's.
Photos at: http://www.communicomgroup.com/jmtruck
Modifications:
K&N FIPK
My problem with the steering extension was that it was too small to fit onto the shaft. I had to use a Dremmel and grind it down just till it fit snuggly. I did notice a little play in it a couple weeks later and rechecked the allen screw that tightens it down. Like JMTruck said, I thought it was tight also, but after trying agian, it did tighten even further, I had to really crank it down. But no other problems since. Does your extension have alot of play in it?
As far as using loctite, they make different grades of loctite, just use the medium strenght(blue), not the permanent grade.
Scott
Scott
There's just alittle play in the extension. I'll try taking it out and retighting the clamp again.
Will say this, It's alot easier than I thought it would be. The instructions make alot more sense while you're working on the truck.
