Spindles - 2" or 1 " block?
I was looking into getting a spindle lift for my truck and wasn't sure what size I needed to get for the back blocks. I see alot of people here with the 2" blocks, but at my shop they say I need a 1" block. I figure that will give me 6" in the front and 4" in the back. Thats the same size suspension lift that I was looking into originally getting. So wouldn't that be the same as the 3"spindles with a 1" block and a 3" body lift?
1997 Ford F-150
4.2 L V-6
Thrush Turbo Tube catback exhaust
K&N Air Filter
Window Tint
Pioneer 7000R CD player
2 Rockford Fosgate DVC HX2 10's
Rockford Fosgate 500a Amp
Lund bug shield
Vent Shade Vent Visors
GTS headlight blackouts
Bedliner
Chrome Toolbox
3" Body Lift
305/70R16 ProComp Muds
16x10 Eagle 589
Chrome Westin Nerf Bars
Custom Key racing stripes down both sides thanx to some a**hole in the HS Parking lot.
My WebPage
1997 Ford F-150
4.2 L V-6
K&N Air Filter
Window Tint
Lund bug shield
Bedliner
Chrome Toolbox
3" Body Lift
16x10 Eagle 589
My WebPage
Mav-
I put the 3.5" spindles on with 2" blocks, and the front still sits slightly lower than the back. Off Road Unlimited recommended that I put a 1.5" block in the back, but I told them no...I should have trusted them!! I think a 1" or 1.5" is correct even though the Fabtech kit says 2".
2000 F150 XLT 4.6L V8 Auto, SuperCab, Torreador Red Metallic, Magnaflow Cat-Back Exhaust, K&N Drop-in, 265/75/R16 Futura Mud Terrains, Ford Bedliner, Tinted Windows, Steel Horse Billet Grill, Fabtech 3.5" Spindles, 2" rear blocks, Fabtech Performance Shocks
www.geocities.com/y2kf150
This is simple, do you want the truck to be level or the rear to have a slight incline? Once you figure that out, you can choose the right size block. Good luck!
'98 F150 S/C 5.4 V8 4x2, Aggie maroon, spindle lift, blocks and leafs, Rancho RSX shocks, Airaid filter system, Pro Comp 305/70/16, AR Baja 16x8, Dynomax duals, and some other stuff
I emailed and talked to a technician at Fabtech. Both replies indicated that the spindles are 3.5" NOT the 3" listed on their website. Maybe that's why they are recommending the 2" blocks in the back too.
My Fabtech 3.5" spindles were part number
FTS97159-7, BLOCKS WERE FTSBK2
