Sponsored by: CARiD
2 day old Spindles...AND A PROBLEM!! HELP
Old Jan 11, 2001 | 05:29 PM
DGreen's Avatar
Thumbs down 2 day old Spindles...AND A PROBLEM!! HELP
Okay...Fabtech 3inch spindles installed tuesday and this morning a LOUD CONSTANT squeak began from the wheels. It is only there under 15mph, and you can hear it whether I'm braking or not...!!! I'm a little worried. Off Road Unlimited wants to see it Saturday. I don;t have my new shocks on yet...could that be it. Also, So Cal was pounded with rain yesterday. Could something be wet? Any help would be great. THanks.
2000 F150 XLT 4.6L V8 Auto, SuperCab, Torreador Red, Magnaflow Cat-Back Exhaust, K&N Drop-in, 265/75/R16 Futura Mud Terrains, Ford Bedliner, Tinted Windows, Steel Horse Billet Grill, Fabtech 3-inch Spindles, 2-inch rear blocks
www.geocities.com/y2kf150
Old Jan 11, 2001 | 07:34 PM
ACOLEY's Avatar
Post
Over a year ago when I did my spindle lift, Bullseye had a bad ball joint manufacturer. The ball joints creaked and squeaked like crazy when turning the wheel at low speeds. Also they were extremely dangerous because they were coming apart and people were losing wheels. Sounds like a similar symptom. I'd get it checked ASAP.
Old Jan 11, 2001 | 07:42 PM
G Patricio's Avatar
Lightbulb
I don't believe it's a bad ball joint because Fabtech uses the original ball joints. What you might want to check is the ABS sensor. When I installed my sensors to my spindles, I noticed the passenger side sensor came awfully close to the "target" wheel on the rotor. Maybe it's touching and giving off the squeal.
Let us know what you find out...
99 F150 XLT SC 2WD, Fabtech 7 1/2" Ultimate Long Travel Lift, 3" body lift, Centerlines with 35" BFG Mud Terrains.
Old Jan 11, 2001 | 08:58 PM
JonC's Avatar
Post
Wheel bearings?
