What size shocks?
I am putting a 4" Superlift suspension lift on my 92 2wd f-150. What size shocks do i need? This months Four Wheeler magazine says to take measurments after the kit is installed, however i would like to have all the parts before i tear my suspension apart. This is my daily driver so it has to be done in a weekend.
Another quicky. I bought 4 slightly used 35" Super Swamper TSL tires. The tires say 15X10 is the approved rim size. Will theses tires mount on my stock rims (which i believe are 15X7) even though they aren't the "approved" size?
Thanks,
Jon
Thanks,
Jon
Regarding the tires, it is posible but you will be forcing them too much, they will wear more in the middle since the rim will crown them and basically is not safe.
Regarding the suspension (shocks) I suggest you to call Superlift and I know they will be able to get you the best answer.
My Ride: 1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications:
K&N FIPK
Gibson Supertruck Exhaust System
Stepshield door sill protectors
Performance Accesories 3" Body Lift
Superlift 3" lift blocks
Performance Lift Lips
Gabriel Gas Ryder LT VST Shocks
Daystar Front Anti-sway Bar Polyurethane Bushings
Heckethorn Steering Stabilizer
35x12.5R16.5LT BFG All Terrain KO's
16.5x9.75 American Eagle 589's.
Photos at: http://www.communicomgroup.com/jmtruck
Modifications:
K&N FIPK
I assume that the swampers are 15" wide, or right around there. DO NOT I repeat DO NOT put those tires on your stock rims. You will put too much stress on the rims and you can very easily blow them out. Trust me you will definetly want to go out and buy some new rims.
1997 F-150 Lariat
Ext Cab Short Box
4x4 Off Road Package
3.55 Gears
265/75 R16 Uniroyal Laredo M/Ts
My 2 cents worth
If you're gonna stroke it, POWERSTROKE IT!!!
1997 F-150 Lariat
Ext Cab Short Box
3.55 Gears
My 2 cents worth
