Will 33's fit under my truck?
OK! here goes...
I got my wife to let me get the Fabtech 3" spindle lift and 2" coil spacers. How I did that I dont know! My question is, can I fit 33's under that lift
1998 F150 Triton 5.4L
K&N Air Filter
Pioneer 4100 W/remote
10" Rockford Fosgate Punch XLC 2410
CatBack system with Magnaflow system 3" Pipe
K&N Air Filter
I agree! Be prepared to trim down your front valance a bit though (possibly!) The spindle will widen your front track about 2 to 3".
-JonC-
*Silver 2000 4x2 F150 Supercab
*4.6L Triton V8
*BFG 285/75/16 AT KO's
*16 x 8 Panther Custom 108's
*K&N GenII FIPK
*Custom Cat-back w/ Flowmaster 50 Series
*Fabtech 6.5" "Ultimate" suspension lift
*Smittybilt nerf bars
*Extang Black Max soft tonneau
*Clear corners
*tint/vent visors/air deflector
(no, I did NOT get stuck in
the accessory dept. at K-Mart!)
-JonC-
*4.6L Triton V8
*K&N GenII FIPK
*Clear corners
Yes, I have spindles and 33s with a small trim on the valence.
'98 F150 S/C 5.4 V8 4x2, Aggie maroon, spindle lift, blocks and leafs, Rancho RSX shocks, Airaid filter system, Pro Comp 305/70/16, AR Baja 16x8, Dynomax duals, and some other stuff
Whats the diff between a 3 in spindle lift and a 3 suspension lift? What is the diff in price?? Also, coil spacers. Where can I get them, about how much do they cost, and what the diff between them and the 2"front coils that are $250?
Mav07-
I'll give you the run down on what I know.
1. Replacing the spindles really isn't a suspension lift since you don't alter any of the suspension components or angles. It just lowers the point at which the wheel connects.
2. A suspension lift would involve the 3.5" a-arm lift or the leveling kit b/c you are replacing the suspension components and angles(top arm and coil springs).
3. I guess the coil spacer(placed between the bottom of the coil spring and the bottom a-arm) will also alter the suspension play b/c you are increasing the angle at the upper ball joint where the upper a-arm connects to the spindle.
I can't say much about the prices. I like my spindles b/c the ride is nice. I have 4 Rancho RSX shocks which really makes it nice(3/1 deal at ORW).
That's the best I can do, I'm sure someone else will add some comments.
Mav07
2" Coil spacers cost around $69.00 check this link out for prices. www.truckperformance.com
1998 F150 Triton 5.4L (4x2)
K&N Air Filter
K&N Air Filter
Now this may be complete BS, but I've been told it's possible to fit 285/75x16 (32.9x11.5) under the 2wd and not have them rub unless at full articulation and turning. Can anyone validate this or tell me I'm smoking some good crack? Thanks.
Dimitry
Never let your schooling interfere with your education --Mark Twain
Dimitry
Yeah, I've heard the same thing and I think I have even seen it but I wouldn't do it. Bad idea...
WHat exactly is the difference between the pepboys spacers and the daystar spacers...cause if i remeber correctly the pepboys ones were running like 6 bucks per while the daystar is 70-80.
imagill.
The spacers that Pepboys sell are JUNK. All they sell you is rubber. The 70-80 dollar spacers are made of polyurathane and resist the weather and heat from your engine better plus in a year or so they'll loose their resistance.
K&N Air Filter
K&N Air Filter
Sorry about that! The cheap rubber spacers from pepboys. You get what you pay for
K&N Air Filter
K&N Air Filter
