Sponsored by: CARiD
rear drop
Old Jun 25, 2003 | 07:31 AM
priddyboy's Avatar
rear drop
can i get a lower look than the 2" drop i already have in the rear of my f150........and will i have problems when i drop it lower????????
Old Jun 25, 2003 | 01:11 PM
01screw's Avatar
The 2" rear drop gives your truck a level look, if you drop it further, you may have to lower the front also, just to maintain a level look. There are many 2/4 and 3/5 lowering kits available from several manufacturers and they aren't that hard to install. Back to just lowering the rear more, I guess the next available drop would be the 4" which is done with a hangers/shackles kit. The hangers are a bit of a bitch as the original ones are riveted to the frame and the rivets have to be cut off and punched out in order to bolt on the new hangers.
Old Jun 25, 2003 | 02:17 PM
suds5.4's Avatar
There are other ways than what was just mentioned. What exactly are you trying to do?
Old Jun 25, 2003 | 02:28 PM
sacto150's Avatar
You can also get 4" or 3" drop leaf springs, I believe Johnny Lightning Performance has 3" shackles available too.
Old Jun 26, 2003 | 07:29 AM
priddyboy's Avatar
rear drop
i want the rear end lower than what it is now...it still has a lil incline to it and i want it even or lower than the front.........thx for the help
Old Jun 26, 2003 | 09:21 AM
suds5.4's Avatar
The cheapest and easiest option is to try the JLP 2-4" adjustable shackles. Your next options would be a rear hanger or new drop leafs.
