Sponsored by: CARiD
Needs some help on a Noise
Old Oct 17, 2000 | 12:29 AM
CodeBlue's Avatar
Question Needs some help on a Noise
I have a noise when I hit the brakes that sounds like a wear indicator hitting the rotors. But only happens when I switch gears and then let off of the brake or it will happen when I have traveled like a block and hit the brakes. The noise is just one click one from both sides of the frontend. I have checked the center caps and had the tires rotated and it still does it. I don't hear the back ones do it. It sounds very similar to what a rock in the tire sounds like. This is very hard to describe and I have planned on taking it to the Ford place but I would like to know what it possibly could be before I take it. I would appreciate any help. THANKS :-)
2000 F-150 XLT, 5.4L, 3.55 Reg Axle
Regular Cab Shortbed 2WD
MODS
K&N FIPK
Kenwood CD and CD Changer
Kenwood Door Speakers
Flowmaster 40 Series Muffler (42541)
Old Nov 7, 2000 | 11:03 AM
lariat4wd's Avatar
Post
Just a shot in the dark, have you checked your shock mounts? I had an older Trans Am that used to do the same thing. I had to replace the shocks. The rubber bushings were tightened down so much that they we not between the nuts & washers any longer. Just an idea. Could also be a front caliper issue, but you said it was both sides didn't you? Hmmm...let me know.
2000 Ford F-150 Super Cab Flareside 4x4 Lariat Black/Silver, 5.4L, 3.55LS, Off-Road, Class III, Installed accessories included so far are: Lund X-Terminator bug shield, Vent Shade Vent Visors, GTS headlight blackouts, Westin Black nerf bars, more to come soon... visit http://www.bmgsite.com and http://www.isurfwebdesign.com and
[url="http://www.bmgsite.com/truck"][URL=http://www.bmgsite.com/truck[/url]
