Sponsored by: CARiD
Shock Opinions?
Old Oct 22, 2000 | 09:32 PM
MNM's Avatar
MNM
Question Shock Opinions?
I've got the factory dual shock setup on the front of my 92 F150 4x4. I need to badly replace the stock shocks I'm riding on. Anyone have any opinions about what would be a good replacement set, keeping in mind that I'm replacing 6 shocks not 4 so something that won't break my bank account would be nice. I've heard that because there's 4 shocks up front I don't really need a stiff shock because there are 4 doing the work of 2. Thanks in advance fellas.
Old Oct 26, 2000 | 04:47 AM
MNM's Avatar
MNM
Question
Hello....anyone....Beuller....Beuller....anyone... .Beuller?
Old Oct 26, 2000 | 07:56 AM
JMTruck's Avatar
Post
MNM
I've heard good things about Ranchos and you know that. But those may break your bank account like the Edelbrock's and the Bilstein's.
I am getting four Gabriel's Gas Ryder LT VST (Velocity Sensitive Technology). Even though I am buying mine here in Puerto Rico from a local distributor, you can find those at JCWhitney for $24.99 and may be lower with the different promotions and sales they run all the time. They have the Quad's for your truck. In my case I just call yesterday and the fronts for my truck were in back order until the end of november, and that's too much of a wait for me. There's one blown shock in the front already and all the bushings are a mess. One thing to take into consideration is that this Gabriel's come with rubber bushing and usually the more expensive units will come with polyurethane bushings and this is a plus. It's your call and good luck.
1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications: K&N FIPK, Stepshield door sill protectors, Performance Accesories 3" body lift, Lift Lips and Daystar front anti-sway bar polyurethane bushings.
See photos at http://www.communicomgroup.com/jmtruck
Old Oct 26, 2000 | 02:56 PM
sdlfb's Avatar
Post
I've had pretty good luck with the Monroe reflex. Right now they're 4 for the price of three. They are a little stiff, but I like that "truck feel".
97 F-150 4X4, 4.6L, 5spd, 3.55, XLT, rcab, flareside, b red, keyless entry, Monroe Reflex, K&N, Kenwood head unit & 10 disc changer, last but not least, ds door-crack!
Coming: Ravin Z-55, Airaid FIPK
96 F-350 PSD, XLT, Auto, 4.10, 4X4, Largo flatbed
94 F-150 4.9L, XL, 5spd, 4X4, Kenwood CD
Old Oct 26, 2000 | 08:41 PM
Matt90GT's Avatar
Post
Since you have the dual shocks up front, you HAVE to get shocks valved for that. otherwise you will have a pogo stick ride up front!
I know that Rancho makes the 5000s & 9000s in dual shock valving. I am sure most other manufacturers do also. I will be a different part number than a bronco or F150 with single front shocks.
Old Oct 26, 2000 | 10:55 PM
MNM's Avatar
MNM
Post
Thanks for the info guys. Are the Gabriels and the Monroes designed for the quad shock setup? The reason that I ask is my buddy who is also my mechanic said what Matt said, "If I don't get a softer shock I will be driving a truck with a pogo stick for a front end." From what I understand you've got 4 shocks now doing the work of 2 so it's not neccessary to have a stiff shock up front. I do a LOT of hunting and where I need to go I have to trust that the shocks are up to the challenge.
Old Oct 27, 2000 | 07:50 AM
JBRIII's Avatar
Post
MNM,
I had the same set up on my 83 Bronco with a 4 inch lift. I replace mine with ProComp Explorer 3000's. They seemed to do a great job. just about right without being harsh. Much less than Rancho's. I think all six were around $150-160.
JBR
Old Oct 29, 2000 | 11:21 PM
MNM's Avatar
MNM
Post
Thanks JBR! I knew if I waited long enough someone who went through what I'm going through would chime in. Where'd you get your PCs?
Old Oct 30, 2000 | 01:03 AM
JMTruck's Avatar
Post
MNM
Yes, the Gabriel's come in the Quad Version. You can call JCWhitney and they will let you know about availability. Price is $24.99 for each unless you can get a catalog with a promotion like I did for my last order. For example: orders over $150.00 get 15% discount.
