need your help!
I noticed yesterday that my truck was leaning to one side. So took measurements. . . my passanger side is 1/2 inch lower than the driver side in the front and back.
I had a 3/4 belltech drop kit proffessionally installed about 2 months ago. I would normally just take the truck back to them put I live 3 hours away from where I had it installed.
I checked the obvious: tire pressure
Can anybody tell me how this can be fixed?
This is probably giving me uneven tread wear right?
Please help, I want to have this fixed ASAP
Thanks,
josh
Thanks,
josh
There has been a lot of speculation about this on the board so you might want to do a search on the topic but here is what i remember. Most agree that the drivers side is set higher to account for a full tank of gas and large drivers. Try measuring with a full tank and a 250lb person in the drivers seat. Should then be close to level. That is if the drop was installed properly. Most chevys are also set this way so its not just Ford. Anyways, i hope this helps a little
