Sponsored by: CARiD
Rear shock removal.
Old Jun 10, 2003 | 03:13 PM
Bartruth's Avatar
Question Rear shock removal.
How do you remove the top nut from the rear shock without the upper part of the shock turning also?
Old Jun 10, 2003 | 10:49 PM
draggin frame's Avatar
I used my cutting torch. but you can also take a box end wrench on the nut and use a small wrench on the top end of the shock or a pair of vice grips will work in a pinch. if this doesnt work any local tire store will install them for about 20 bucks usually.
Old Jun 12, 2003 | 09:13 AM
Glenn Mc's Avatar
There is a second nut located on the shock stud, below the frame member that the shock passes through. On the F150 it is an 18mm nut. There is a hole through the frame to allow wrench access. I just did mine, it was fairly easy. GlennMc.
Old Jun 12, 2003 | 11:43 AM
APT's Avatar
APT
I first did the monkey wrench thing like dragging frame, then found the second nut. Easy after that.
