'92 F150 questions
Hey fellas-
I own a '92 F150 SC 4X4 302ci. I bought the truck used a few months ago. The only hop-up I've done is I had the heavy duty front leveling coils installed and the front end was noticeably lifted about 2" (level with the back). However, there are a bunch of questions that I had for all you FF's (Ford Freaks):
1) The rear end of my F150 is noticeably leaning to the driver's side. Is there a fixable reason for that? Shims?
2) Will the rear leaf spring packs from an F250 of the same model (92-96) fit my truck?
3) How much lift does an add-a-leaf add and will it fix my lean or just make it worse?
4)Would a 1" block make a huge difference in the driveline angle?
5)I have the dual front shock assembly and all 4 shocks need replacing (the shop installing the front coils BROKE all 4 shock studs in getting them off). What brand shock won't make the front end so stiff it hops like a pogo stick? Hopefully not some brand that's going to break me in the wallet.
Thanks in advance fellas.
