Sponsored by: CARiD
Best way to level out the front end?
Old Sep 14, 2000 | 03:41 PM
Jackal's Avatar
Question Best way to level out the front end?
I was looking at the truck today, (again) and decided that I wanted to raise the front end to be more level with the rear. I've heard of people adjusting the torsion bars, and I've also heard good, and bad things about it. I read my new owner's manual, and I found nothing about "adjustable torsion bars." What's my best bet? It'd be nice to adjust the bars, but I only have 900 miles, and don't want to, A: have to get an alignment already, and B: screw anything up. (i.e. the TOE.) BTW, what is the TOE? TIA!!!
Damn, too many acronyms.
-AR
- 2001 F-150 XLT 4X4 Off-Road, S/C, FS, Black
- 4.6L Triton V8 (20 H.P. Increase)
- 5 Speed / 3:55 Reg. Axle
- Keyless
- Premium Audio CD
- Mods.
- K&N Cold Air mod.
- Flowmaster 40 (Stock Setup with 3 1/2" Gibson Tip)
- Bugshield
- Bedliner
- Ventshades
Old Sep 14, 2000 | 05:25 PM
lightningcrashz's Avatar
Post
Torsion bar cranking is definately the cheapest including the cost of an alignment.The downfall is it will drive alot more rough than before.WHen you crank the bars, it makes the tires wear the outside of the tread,unless it is aligned.I did it to my truck and it looks so much better I don't mind the stiffer ride(after all it is a truck.
JET air filter
delta tool box
pumpin' stereo
class III reciever hitch
spray in bedliner
headlight covers
custom painted taillight covers
cranked torsion bars 2000 black F150 4x4 sport v-6
lightningcrashz@hotmail.com
Old Sep 14, 2000 | 11:19 PM
Jackal's Avatar
Question
Thanks man...what how does this effect the "TOE"? I've also heard that this may cause the torsion bars to "snap." I've messed up too many "toys," doing stupid-kid things. BTW, I'll be 21 in 2 months.
-AR
- Keyless
- Premium Audio CD
- Mods.
- K&N Cold Air mod.
- Bugshield
- Bedliner
- Ventshades
Old Sep 15, 2000 | 04:41 AM
Post
I have never heard of torsion bars snapping.wierd.If you are afraid to do it yourself you local alignment shop should do it for ya.My local shop said it would costaround 75 bucks for the crank and alignment.They also said they wouldn't raise it up more than 1 1/4 inches.Mine is raised 1 3/4 inches and it is level.I had a friend and longtime ford owner help me out.I didn't even know where to find the bolts to crank.He also had an air ratchet set .took all of 5 minutes.maybe less. The toe is kinda hard to explain.(at least for me)cranking the torsion bar somehow puts most of the weight of the front end on the outside edge of the tire-like the tires are pinching inward(actually they are).that makes the truck only want to go straight.It felt wierd until I got the alignment.If ya like your tires make sure and get the alignment done asap after the cranking.BTW I am only 27 so I can relate.Could you post a picture of the fender to airbox side of your modified airbox?
JET air filter
delta tool box
pumpin' stereo
spray in bedliner
headlight covers
Old Sep 15, 2000 | 08:53 AM
Jackal's Avatar
Thumbs up
Thanks again man, I get what your saying. I wish I could post a pic, but no digi. cam. yet. If you missed it, theirs a thread in the Engines forum titled, "The Ultimate Airbox Mod....Cheap Too!!!" That'll tell you everything you need to know.
-AR
Jackal's Avatar
Thumbs up
-AR
