Sponsored by: CARiD
loose rivets in frame
Old Sep 9, 2000 | 10:42 AM
jfox's Avatar
Post loose rivets in frame
I have a 95 f-150 extend a cab long bed.The rivets have losened up in the frame and not makes a popping noise.Does any one know of a recall or warany that ford has that would cover this. Does this pose as a safty hazard?
Thank you for any help
Jeff
Old Sep 9, 2000 | 11:49 AM
JMTruck's Avatar
Exclamation
jfox
I don't know about recalls or TSB's for 95. But if it is not covered by warranty I would put in there new rivets or nuts and bolts in place right away, from the safety standpoint.
1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications: K&N FIPK, Stepshield door sill protectors, Performance Accesories 3" body lift and Lift Lips.
See photos at <A HREF="http://www.communicomgroup.com/jmtruck
" TARGET=_blank>www.communicomgroup.com/jmtruck
</A>
Old Sep 9, 2000 | 01:03 PM
jfox's Avatar
Post
Do you think I should try to get a hold of ford and Let them know The frames are loosing up and the rivets are a mafacture defect?
Old Sep 9, 2000 | 04:02 PM
Y2K 7700 4x4's Avatar
Post
I remember my friend complaining about his F-150's frame popping and it needed rivits replaced.
Ford later came up with a couple "service tips" relating to "popping or creaking noise" back in 1Q97 which had something to do with replacing the rivits in the frame with bolts.
Tight-fitting grade 8 shoulder-bolts in combination with crazy-glue and taper-pin arrangements work well in preventing shifting of framerails.
