Sponsored by: CARiD
1997 F150 front shock replacement
Old Jun 1, 2003 | 07:50 PM
irtristan2's Avatar
Question 1997 F150 front shock replacement
I just purchased new front shocks for my 1997 F150 4x4. I am having a terrible time removing the lower bolt on the old shocks. The nut looks strange to me. Instead of 6 points they have been flattened slightly. I can fit an 11/16 6 point socket on the nut and it is very tight but I have started to round off the nut instead of breaking it loose. Has anyone had this trouble and if so, how did you remove that lower bolt? I have a Haynes manual for my truck but as usual it is worthless. It simply says "remove lower bolt and nut"...
Old Jun 1, 2003 | 09:00 PM
03f150man's Avatar
nut head is probably metric. you may need to use a nut buster socket. I have a set from sears. Just drive the remover socket onto the nut and use a socket wrench to pull off the offending nut. Works great.
Old Jun 1, 2003 | 09:25 PM
irtristan2's Avatar
Metric
I tried metric but nothing fit right. 17mm was too small and 18 was too big... I might take your advice and visit Sears tomorrow.
Old Jun 2, 2003 | 08:11 AM
pjf77's Avatar
Electric impact gun worked well for me. Sorry can't remember the size I used though.
Old Jun 2, 2003 | 01:02 PM
dirt bike dave's Avatar
My '99 was an 18mm. I bought a 6 point socket and wrench just for the task. 11/16" is very close to 17mm.
Old Jun 4, 2003 | 03:32 PM
AKchele's Avatar
Lightbulb
I recently changed the 4 shocks on my 1997 4x4.
The nuts are metric, and if not mistaken I think it is 18mm.
Old Mar 23, 2012 | 12:46 PM
fordfan4x4's Avatar
If the nut is really rusted on and is stripped you can always cut the nut off with a nut breaker or a grinder. then all you would have to do is replace the nut. they r not that much. hope this helps
