Sponsored by: CARiD
HELP! Rust on Lower control arm
Old Jul 30, 2000 | 10:00 PM
Nitrox's Avatar
Post
I know it's depressing seeing your own brand new vehicle with rust. I would simply take it back to the dealer, and express your concerns, they will more than likely just sandblast it off and spray some undercoating on.
Anyways, as thick as the upper and lower A-arms are; it would probably take 25-30 years to completely rust through.
My new 2000 F-150 had some rust around the rear axle, from where they chained it down while transporting it from the plant.
I just got the rust off the best I could with a scotch bright, and sprayed it with some rubberized undercoating.
Hope this helps ...
• 2000 F-150 XLT
• 5.4 LITER TRITON V8
• 4X4 OFF RAOD PACKAGE
• SHORT BED EXTENDED CAB
• BRIGHT RED CLEARCOAT
• GRAY INTERIOR
• AUTOMATIC W / MANUAL 4X4 SHIFTER
• 3" PERFORMANCE ACCESSORIES BODY LIFT
• 33X12.50X16.50 BFGOODRICH ALL-TERRIAN KO'S
• EAGLE ALLOY'S 16.50X9.75 SERIES #143 RIMS
• FORD SOFT TONNEAU COVER
• BLACK POWDER COATED STERLING EQUIPMENT NERF BARS
[This message has been edited by Nitrox (edited 07-30-2000).]
Old Jul 31, 2000 | 12:45 AM
blue2000expy's Avatar
Post HELP! Rust on Lower control arm
My Expedition is brand new and I was shocked to see that the lower control arms are completely covered with rust. This is the part of the front end that connects to the back part of the front wheel's brake assembly. Is this something I should expect from Ford? Has anyone else experienced this? It's a same paying almost $40K and seeing so much rust.
Thank you in advance
Old Aug 3, 2000 | 10:06 AM
Boss96Hog's Avatar
Post
Kill the rust first before you paint or undercoat it. Spray Ospho (available anywhere that sells auto paints) on the rust to chemically turn it to black iron. If you only cover it up with paint or undercoat untreated, it will rust even worse because you just sealed in the moisture and sealed out the air
Boss™
Just Ordered 2001 F-150 Lariat, Oxford White/Silver 4x4, medium graphite leather, SC, SB, SS, 99L 5.4L, 44E tran, 7700# payload, Class III Tow, 3.73LS, Skids, Capts chairs, 4W disc ABS, shift-on-fly, keyless, HD everything
Planned Mods:
"Protected by Smith&Wesson" sticker, Westin Chromed Stainless Nerf Bars, ARE LS II bed cover, Bedrug™, Gibson Swept Side Cat Back, K&N filter w/airbox mods, headers, Superchip, 3" body lift with at least 33's, alarm/pager/auto start system, stereo system
Old Aug 3, 2000 | 11:13 AM
Post
Thanks for the advice. I looked again and to be specific, it looks like the spindles that are rusted. There's a picture of the OEM on roberto's lift pics on this section. It just sucks having seen rust on a brand new truck.
