Sponsored by: CARiD
6" suspension???
Old Jul 23, 2000 | 04:42 AM
Ryshark5's Avatar
Post 6" suspension???
I had my 2000 5.4 lifted up 6". A-arms, spindals, Bilstein shocks, Eibach coils, the whole shot. I had this done 6 months ago and it has always made noises but now it really squeaks over bumps or when i stop or accelerate. Is this normal or does the place i went too suck? Im hoping it just needs to be relubed or something. If anybody knows anything about gear ratios, what size gears do i need now? My stock tires were 235 R16 and know i have 285/75-16. My current gears are 3:55.
Old Jul 23, 2000 | 11:49 AM
sdiesel316's Avatar
Wink
Hey Ryshark5, Im not too familiar with 2wds, but with 6" of total lift, one would have to expect some sqeakiness and some bad characteristics to come from their truck.
As for the gear changing....if you're running 285's with the 5.4 liter engine, you should be ok, but if you're like me and notice just a tiny bit of acceleration missing from your truck, a set of 4.10 gears would bring you back up (and add a little too), but if you are ever planning on going bigger, like to a 35" tire, 4.10's would still be fine, but if I were you, I'd move all the way up to 4.56. Just my two cents worth, have a nice one!
Old Jul 23, 2000 | 03:30 PM
G Patricio's Avatar
Post
Ryshark5,
You didn't say if the rear of you truck had been lifted at all and if so, how. The front squeaking may just be the upper control arm bushings in need of lube. I know fabtech has zerk fittings, I don't know about camburg. Also, check your shocks. There is enough play at the top mounting hole of your front shocks that you can actually mount your shocks so they touch the inside of your coil springs.
As for the rear, if it was lifted with "add a leafs", they could squeak when accelerating when the rear "winds up", causing the "add a leaf" to rub against the original spring pack.
Just my 2 cents....
99 F150 XLT SC 2WD, Fabtech Suspension, Bullseye Spindles, 3" body lift, Centerlines with 35" BFG Mud Terrains.
Old Jul 23, 2000 | 04:33 PM
Ryshark5's Avatar
Post
I appreciate everybodys 2cents. Souds like a lot of good suggestions. The back of my truck has 3" spacers and two bilstein shocks. CR1, youre right i did get my lift done at Camburg in Huntington Beach. I think im going to go with the 4:10. The ratio closest to your equation. Hopefully it is only the a-arm bushings, im going to call a lift shop and see what it runs to get them lubed.
2000 5.4 Regular Cab 3:55ls(soon to change)
6" suspension lift (bilstein and eibach)
Weld Racing Rims
285/75-16 BFG all terrains
3"catback w/ flowmaster
Jet air intake
billet Grille
Viper alarm
superchip(in the mail, should be here soon)
Old Jul 24, 2000 | 12:01 AM
CR1's Avatar
CR1
Post
Hey, RyShark, we need to see some pics of your truck. Sounds like the same setup I will have one day. Since we are from the same city, maybe I could take a look at the truck. The squeakiness may just be from the bushings on the A-arms. Sounds like the Camburg kit if I had to guess, and I know they stand behind their product. Where did you get your lift done? Let me know, and hopefully we can get together sometime.
*1999 2WD XLT 4.2L 4R70W Auto
*3.31 8.8" Rear End
*3" Bullseye Lift Spindles
*275/70/16 Dunlop Radial Rover A/T's
*Borla Catback
*Airaid Intake
*Clear Corners
*Alpine 5-Channel Amp
*4 Pioneer 6815 Speakers
*1 Rockford Fosgate Punch 12" Subwoofer http://www.geocities.com/cr1f150/mytruck.html
[This message has been edited by CR1 (edited 07-23-2000).]
Old Jul 24, 2000 | 12:36 AM
ilmagill's Avatar
Post
The lift shouldn't sqeak at all. The fact that you have 6 inches of lift means nothing, because the coils don't sqeak and the spindles just change the location of where you mount the tiress. I would go get it checked out cause somethings wrong. My 2 cents.
1999 4.2l 2wd super cab F-150 3.55 gears LS Mods: 3in body lift, 285/75 R16 BFG AT, suglid tonuea cover (white) 10 disk changer K&N Air Filter Tow package 6000 Lbs GVWR
Things to come: 4.10 gears, Flowmaster 40 series Delta, Superchip, Grill
