Can you mix and match lift kits?(2wd)
I have read alot about different lift kits for 2wd f150s and was woundering something. If was to buy the 4inch rancho kit(includes 1inch spindles, 1inch coils, 2inch a-arm relocater)could i later add in fabtechs upper and lower a-arms, their 3inch coils, and their 3inch spindles. all of that plus a 3inch body lift would be 12.5 inches of lift. Could I fit 38s with that lift?
1999 F150 REG.CAB BLACK 2WD SPORT 4.2 LITER V6
JDsF150@austin.rr.com
[This message has been edited by JDm (edited 07-10-2000).]
- FLOWMASTER SERIES 40 DUAL EXHUAST
- K&N Filter Injection Performance Kit
- MANIKS GRILLE GUARD
- PIONEER DEH-P4000 CD PLAYER WITH 4 3WAY SPEAKERS
- SPIDERGEAR BED WEB
- PROCOMP HEADLIGHT BLACKOUTS
- 1.75 INCH COIL SPACERS(gave me 3 inches of overall lift).
- 3 inch body lift
- 33x12.50R16(305/70r16) Procomp Mudders
- 16x8 American Racing BAJA rims
I doubt that you'll get 12.5 inches of lift...because the 3inch spindles will replace rancho's 1 in, their 2.5 inch coils would just replace ranchos, and their A arm kit would probably wipe out ranchos a arm relocater...so you just have fabtecs 6.5 inch lift kit. They have a long travel 7.5in long travel kit...its huge.
1999 4.2l 2wd super cab F-150. Mods: 3in body lift, 285/75 R16 BFG AT, 3.55 gears, snuglid tonuea cover (white) 10 disk changer K&N Air Filter Tow package 6000 Lbs GVWR
I might be mistaken, but I believe that all lift spindles made for the 2wd F150 by any manufacturer is a three inch lift. Rancho gets the 4 inch lift with 3 inch spindles and coil springs combined with dropping the lower control arms for 1 more inch. As far as I know the tallest lift available for 2wd's is the 7 1/2 lift by fabtech. I last priced it at about 3300.00 with dual shocks. Fabtech says that with a body lift, you can safely run 37 inch tires. I'm sure that's conservative. Also, Fabtech now has front fiberglass fenders with a 3 inch bulge. I haven't verified whether that will get you more room for tire size or just travel.
<img src=http://home.san.rr.com/patricio/twotrucks.jpg>
<img src=http://home.san.rr.com/patricio/f150.jpg>
99 F150 XLT SC 2WD, Fabtech Suspension, Bullseye Spindles, 3" body lift, Centerlines with 35" BFG Mud Terrains.
[This message has been edited by G Patricio (edited 07-10-2000).]
