Am I remembering everything for a 2/4 drop?
I plan on doing a 2/4" drop on my truck. I already have shackles, so I am wondering what I need to complete this successfully. I plan on purchasing 4 Edelbrock IAS shocks, hangers, 2" Belltech coils, and a pinion? shim. What else am I forgetting regarding the front or rear? I know I need to get an alignment done after these mods, but do I need to alter anything else? It seems like the 2" shackles have only brought the rear to 2" above level. Can anyone give any input as to if anything is feakishly wrong? Thank you in advance for all of your help- I can always count on F-150 Online!
2000 Reg. Cab Flareside F-150, 5.4 Sport in Black: K&N, Flowmaster 50 w/ Borla square side exit tips, 2" lowering shackles, Pioneer CD, Infinity Kappa Components, Rockford Amp and 12" DVC sub.
That should do it. Personally I like the 3" coils. Just make sure that you install new upper A-arm cam bolts instead of the factory ones with the square washers. You will need this for alignment. I believe they come with the Bell Tech stuff though, so you should be ok.
