Sponsored by: CARiD
Bell Tech 4x4 Lowering Kit
Old Apr 19, 2000 | 03:46 PM
DynoDan's Avatar
Banned
Talking
Well the truck used to have a sever "rake". I just wanted to level the truck, slightly lowered, not slammed. The rear fender used to be @ 40", now it's 35.5". The front was 37" now it's 34 5/8".
Seeing that my truck is brand new, the install was pretty easy. The front end is very straight forward if nothing is "frozen up". The rear end is a little tougher because you have to swap hangers and shackles. I slotted the rivet heads, air chiseled them off, pryed off old hanger, ground rivets flush, and then air chiseled them out the back side. I had a spacer between the springs and the axle pad (factory), and I left it in place. If I removed it there would have been another 2" of drop.
I had a slight vibration @ 20-22 mph, but then I installed their 6 degree shim. The shim got the pinion angle back in spec, and no more vibration.
Yes I did it myself (w/ a buddy), and it took us most of the day. Better order it soon, it sounds like they are pulling their 4x4 kits of the market. I guess there isn't enough interest in them.
2000 F-150 XLT Styleside
-4x4,Reg.Cab, Short box, White, Sport, Bell Tech lowering kit
dwh@dynojet.com
Old Apr 20, 2000 | 09:16 AM
Chris Thomas's Avatar
Post
Those hangers were a bit@h to get off weren't they. That is the same way I lowered the rear of my 4x2. It did take pretty much all day, even with air tools.
Truck looks great though!
Chris Thomas
<A HREF="http://216.147.104.171/Y2K/members/ChrisT/christ1a.jpg" TARGET=_blank> </A>
1998 F-150XLT Flareside STX Sport Package, 4.6L Auto 3.55 Oxford White/Gray interior, Factory Anti-theft system
Picture: http://216.147.104.171/Y2K/members/ChrisT/christ1a.jpg
Homepage: Chris & Brandi's Universe
Mods: A.R.E. Decklid/Oxford White with gray fabric liner, K&N filter with Airbox Mod (removed silencer), Lowered 3" front/5" rear, Tinted Windows, GTS sloted taillight covers (painted Oxford white to match), Removed STX stickers
Audio: Kenwood Truck speakers with 10" woofers, Rockford Fosgate and Alpine Amps, Ford 10 disk CD changer
Future Mods: 20" rims and tires, True duals with Supertrap tunable mufflers, Superchip, Supercharger, Jacobs Ignition, and whatever else I can think of!!!
[This message has been edited by Chris Thomas (edited 04-20-2000).]
Old Apr 24, 2000 | 09:33 PM
snocat's Avatar
Post
How's the ride and handling? Did you change shock's? I understand Belltech offers gas shock's for this kit. Do you tow a trailer and how big?
Old Apr 25, 2000 | 01:46 PM
DynoDan's Avatar
Banned
Talking
The handling was greatly improved (tires help a lot) and I also plan to add a rear sway bar. The ride is about the same as stock, very harsh. I have the trailer package, which I believe added "heavy duty" shocks. The only trailer I tow up here in "6 month winter land" is a two place snowmobile trailer. No 40' off shore boat in this guys driveway!
4x4,Reg.Cab, 120" WB, White, Sport Pkg., Bell Tech lowering kit, Gen II Lightning Wheels, B'stone 285 60 18 tires
dwh@dynojet.com
Old Apr 25, 2000 | 02:19 PM
BassDean's Avatar
Post
Dyno Dan - QUESTION
How did you relocate the parking brake cable. Mine does not have much slack to pull away & tie back. I read another post where a guy had a problem with interference with a brake hose mounting bolt? His was a 4x2. I have a 99 reg cab 4x4 with 4.6 auto & 3.55 gears Do not have off road package).
L wheels with p285x60 michelins ordered & on the way!!
Thanks for the info!
BassDean
Old May 1, 2000 | 02:16 PM
DynoDan's Avatar
Banned
Talking
You shouldn't really have to worry about re-routing your p-brake cable. I had to do it because I lowered it. I ran the passenger side cable under the driver's side spring (used to go over it). The bracket that Bell Tech gave me was never going to work so I used the stock piece, just different location. You will have to fab a small bracket to space out (towards center of truck) the mounting location at the driver's side tire with the L wheels and 285's. The driver's side cable rubs on the tire/wheel because of new size and offset. If any of this in unclear just email me and I can even shoot some pics.
Good luck, you'll love the tire/wheel combo! The upper control arms on the front end are close to rubbing, but there is space (1/2").
dwh@dynojet.com
[This message has been edited by DynoDan (edited 05-01-2000).]
Old May 5, 2000 | 01:41 PM
38-chevy's Avatar
Talking
DynoDan,
Glad you liking your lowered 4x4. I decided against doing it with my 4x4 and instead just traded it in on a 2k silver lightning!!
Thanks for your input on the belltech system
38-chevy
2000 Silver Lightning
2000 Silver Grand Am
1996 Honda Shadow A.C.E.
1993 Rudy Covette
1938 Red Chevy Coupe
