3" body lift
hope you guys can shed a little advise:
I have a 2000 f-150 off road and plan to add a 3" body lift specifically Performance accessories (JC Whit.). I want to go with Super Swamper TSL/SX 35" but the only width offered w/ the 35 is 15.50 is this size possible w/ my lift w/o rub even if I crank the torsion bars slightly???If not I'll have to go with the reg. Swamper style...would 35x12.50's work??? and finally w/ this a 3" lift do I have to extend the brake lines and bleed the system??
I have a 3" body lift on my truck with 33x12.50's and do fine. There are many people on here who run 35x12.50's without any rub. If I went with 35's I would have to trim that black valence piece under the bumper to fit them. I am doubtful that 15.50's would fit. No Brake adjustments were needed.
1997 Ford F-150
4x4, 4.6 V8, 5spd
extended cab, XL
Silver
Mods:K&N Air Filter, Flowmaster 70 series 2 chamber muffler,Rancho RS5000 shocks, 3" Performance Accessories body lift,33x11.50 Durango M/T's, Westin Nerf Bars,Tinted windows, Front Blackouts,Alpine CD player, Rockford Fosgate Amp,12" Kicker competition VR sub,
"THE HEARTBEAT STOPS HERE" sticker on windshield
http://hometown.aol.com/ad%20offRoad/index.html
1997 Ford F-150
4x4, 4.6 V8, 5spd
extended cab, XL
Silver
In have a 97 with a 3 inch body lift and 35x12.5x16 BFG ko's. My truck doesnt have the orp. The tires do rub on the mud flaps at almost full steering lock. I havent had my torsion bars cranked up. I believe that would fix the problem. I put the tires on 8 inch rims. 10 inch rims would probably rub alot worse.
I have 33/12.50 super swamper TSL's on my truck at the stock height. I took the front valance off and it rubs a little bit on the inside of the wheel well when u go over a big bump on a hard turn, other then that they are great. I am getting a 3" body lift very soon and heard that the kit recomends 36/12.50's, which i hope is true.
Rhino Lining sprayed to entire body of truck, custom built rear bumper, custom roll bar, 5 point harness seat belts, 33/12.50 super swamper TSL's, 5.4 motor, 3.73 gears.
i heard that a 3inch body lift will drop my 5spd 3inchs. Has any one had this problem and can i buy a shifter extinsion to correct the problem. with the 3inch body lift on my 2wd truck can i fit 285/75r16s.
1999 F150 REG.CAB BLACK 2WD SPORT 4.2 LITER V6,FLOWMASTER SERIES 40 DUAL EXHUAST, K&N FILTERCHARGER, MANIKS GRILLE GUARD, PIONEER DEH-P4000 CD PLAYER WITH 4 3WAY SPEAKERS.
JDM,
Yes, you will be able to run 285's with a body lift. Some guys on here are runnin 285's with no lift on there 4x2 and they have no problems. Good luck.
Love 24wheel,
Do you have any pics of your truck, would like to see it with the roll bar, thanks.
Patrick aka Mudder or MR.Daylighter of Arlington Texas (D/FW), member of the Texas Chapter club DAYLIGHTER edition F150 ®, Black 98 S/S S/C F150 4x4 0RP 5.4 3.55ls, Ramsey Pro 8000 hidden winch, Grizzly roll bar, Superwhite Bulbs, 2 Baja back up lights, 8 165 watt KC Daylighters, 4 chrome, 4 black (I come alive at night), Manik grille guard, Westin step bars, Rhino Taillight guards (thanks Pony), Magnum bug shield, Sonic aluminum treadplate 36" tool box, Flowmaster 40 series dual exhaust, Airaid High Flow system, Edelbrock IAS shocks, 285/75/16 BFG AT/S KO, American Racing Baja wheels, Cobra CB radio with 3' whip antenna, Escort Laser/Radar detector, Nokia cell phone, a Mobil Speed Pass on the back window, a F150 Online sticker, and a DAYLIGHTER sticker on the front windshield, and yes, I also have been infected with the infamous door crack. More to come for the Daylighting machine: JBA headers, superchip, and a Lighted Ford tailgate logo. If you would like to see pics, email me at mudder46@hotmail.com or see pics at me and pony's website www.angelfire.com/ok3/ponysix8 , and to hear the Flowmaster exhaust http://www.angelfire.com/ok3/ponysix8/images/T005.wav
Also the Moderator of the Ford Trucks vs. GM trucks forum over on fordvschevy.com so check it out.
Check out the Toughest SOB in the WWF crush the Rock's Lincoln: http://www.amta.net/files/sc-2.avi
OH HELL YEAH!
Mr.Daylighter "Go ahead, flash your brights at me, see what happens"
I am the brightest around, and that's the bottom line, so take your little Piaa's or Hellas and get out of here.
[This message has been edited by mudder (edited 04-25-2000).]
Love 24wheel,
OH HELL YEAH!
how hard is it to install kc lights on a manik grille guard that is predrilled.
1999 F150 REG.CAB BLACK 2WD SPORT 4.2 LITER V6,FLOWMASTER SERIES 40 DUAL EXHUAST, K&N FILTERCHARGER, MANIKS GRILLE GUARD, PIONEER DEH-P4000 CD PLAYER WITH 4 3WAY SPEAKERS,SPIDERGEAR BED WEB,PROCOMP HEADLIGHT BLACKOUTS.
how hard is it to wire them and install the swicth on the dash some where
Hey Mudder,
I've mounted two KC's on my Manick about a year ago. I'm wondering if you had experianced the same problem that I did when I tried to bolt them down.
The predrilled holes on the Manick were from topside were OK, but the bottom hole was not wide enough in diameter to allow the rubber vibration washer to be inserted through the hole. Each light came with two of these rubber anti-vibration washers, one which was to be used on top of the mounting surface and one on the bottom of it. I actually had to rumage for longer mounting bolts that would extend vertically all the way through the two predrilled holes so that I could utilize the rubber vibration washers from the bottom, as well as from the top of the Manick mounting surface for the KC's. The original bolt that came with the lights to mount them with was not long enough to extend all the way through the Manick light mounting platform to accomodate all of the washers, and the nut itself. Your thoughts and experiance with it....?
1999 F150 4x4, wedgewood blue, 5.4l auto, Manick brush guard, Duraliner, KC Hilites, surf rod holders, tinted windows, K&N air filter without airbox, Velocity air intake tube, Midas Performance muffler with dual pipes, toolbox, Uniden CB with whip, and a Superchip.
I know what you are talking about. But what I did was make a light bar that bolts to the two holes on the Manik, so I didn't have to mess with the bolts and washers not fittin through. But I had two Baja lights on the front before I added the KC's, and that wasnt a problem. They just don't give you much room to work with under there. I think what some people do is grind the hole enough to where they can get in there. Here are some pics of the bar:
[This message has been edited by mudder (edited 04-27-2000).]
That's very clever, thanks Mudder...
-kindest regards
-kindest regards
