Sponsored by: CARiD
Does a body lift need new shocks
Old Apr 14, 2000 | 12:56 AM
ilmagill's Avatar
Post Does a body lift need new shocks
I got a 3in body lift on my f-150 and the ride went down hill....i guess it could have been the tires (BFG's) i tried various PSI's and the truck still rides alittle rough. Is this because the shocks are over extended in the back. If so does anyone have any cheap recomendations to what type i should get and where i can get theminstalled. Also how do you post pictures on the site?
1999 4.2l 2wd super cab F-150. Mods: 3in body lift, 285/75 R16 BFG AT, 3.55 gears, snuglid tonuea cover (white) 10 disk changer Tow package 6000 Lbs GVWR
Old Apr 14, 2000 | 01:27 AM
franks&beans
Guest
Posts: n/a
Cool
There are two things you will need for your truck now you have a body lift.
1. Edelbrock shocks, part numbers for 2WD Front (3350) Rear (3450)
2. Hellwig Anti Sway Bar
You can thank me later.
F&B's
98 F-150 XLT, SC, SWB, 2WD, Pac. Grn., 4.2L auto, 4.10 gears w/ LS, Tow Pkg., BFG AT's 265/75/16, K&N air filter, Dynomax muffler, Superchip, Edelbrock shocks, Hellwig sway bar, 3" body lift, signal mirrors, ...tons of cosmetic products
Old Apr 14, 2000 | 01:31 AM
DAVENSA's Avatar
Post
1) No you dont need new shocks when you add a body lift, shocks go to the frame not bed.
2) The reason your ride is suffering alittle is because the BFGs have a very thick side wall and don't give in like the crappy street tires Ford sells with the trucks......You will find that you handleing though has probably improved though, since tire roll has eliminated.....DAVE
1998 F-150, SC/Flairside,oxford white 4x2,4.6,auto,3.55s,nerf bars,cls 111 towing,bed liner w/mat,atlas polished wheels w/285/75 R/16 BFG A/Ts (black side out),all plastics guards/bug shields,air raid/k & n filter, superchipped, duals out the back corners, flow master 3 chamber, snug top lid, f-150 online sticker back window-honk if you see me!!! Fabtech 3 1/2 lift .coverking dash cover, Lumi Logo's (front and rear), clear front corner lenses, muth mirrors.
San Antonio
DWESSELS89@AOL.COM
Old Apr 14, 2000 | 09:15 AM
ilmagill's Avatar
Post
Do you guys have any recomendations for the tire PSI setting, im runnin 43psi right now.
Old Apr 14, 2000 | 02:21 PM
Loser1's Avatar
Question
What???? After this 3" body lift, is my ride gonna suck? It should remain the same right. I mean, I'm not changing my suspension.
Help, i'm starting to get cold feet w/this body lift thing.
Old Apr 15, 2000 | 12:45 AM
franks&beans
Guest
Posts: n/a
Red face
Tire pressure 43PSI!! That's a little high. I run 35 PSI in all four tires
F&B's
Old Apr 17, 2000 | 04:42 PM
Florida Ford's Avatar
Post
awww...don't get cold feet...its fun especially if you do it yourself!!! My ride didn't suffer that I can tell but I did put on new Bridgestones roughly the same time I did the lift.
Go for it!
by the way where's CCLA...he's usually put in his .02 by now......????
1997 Arctic White F-150 XLT Flareside SC, K&N, Magnaflow muffler, Air Box mods, Bugflector II, Soft Tonneau Cover, Chrome Westin Bars, 3" Performance Accessories Body Lift, tinted windows
Flares Rule!!!!!
Old Apr 17, 2000 | 05:36 PM
ccla's Avatar
Talking
Consider This My .02 - Pardon my absence from the boards. I was in San Antonio with Dave and the others
NO Like Dave Said you don't need new shocks with the Body Lift. As he mentioned the shocks are mounted to the frame. The antisway bar sounds like a good idea though because of the extra height. Its probably the tires like Dave said.
New shocks Might be a good idea though, unless you plan suspension mods. If you do then wait. No sense buying shocks twice
