73-79 F150,78-79 Bronco lift question
I am going to install a 9" lift on a 78 Bronco, what modifications do i need to make to the Bronco, besides a drop radius arm, drop pitman arm, brake lines, and drive shaft?
Black N Tan,
sorry, this isn't an answer to your question, but I have a soft cover, slant style tonneau, for that truck, if you are interested e-mail me at ginot99@ aol.com. It was only used 2 seasons, its in new condition and I made a custom track for the snaps out of an old hard top.
Gino Tedesco, '99 XLT 5.4l, SUPERCHIPPED, 3" Gibson catback exhaust,4x4 S/C Flareside D.wedge bl/Dk.graph, factory sidesteps & Tonneau cover, Manik grlgaurd w/Piaa lights, 305/70-16 Goodyear Wrangler AT/S tires
http://silverstone.fortunecity.com/s...916/index.html
You may want to shim the rear diff up a little to offset the angle of the driveshaft. Don't go too much or you'll wind up with the pinion bearing running higher than the oil level. You may also want to lower the trans and transfer case a little to help with that also.
1997 F-150, 4.6, automatic, Dark Toreador Red, Supercab, Flareside, 4X4 Off-Road, Towing Package, Ford hvy dty rubber floor mats, Kenwood 10-disk cd changer, Kenwood am/fm cassette head unit, Ford bugshield, Chrome Grizzly Wrap Around Push Bar with 2 KC 100w Daylighters, Ventshades, Ford bedliner, Lund Premier tonneau cover, cab and bed professionally undercoated, Code Alarm Sure Start RVS remote starter, Ford alarm, Realistic CB with Wilson Little Wil antenna and Astatic power mic, ported MAF sensor, and Lots of TLC!! (Besides being an F-150 nut, I am a Ford auto technician.)
