Sponsored by: CARiD
Raise just the front end of a 4x2
Old Feb 28, 2000 | 01:44 PM
Y2kXLTSport's Avatar
Question Raise just the front end of a 4x2
OK, I have seen and read a lot about raising and lowering trucks, but I'm not sure what the consensus is about raising just the front of a 4x2 to make it sit level. Cranking torsion bars seems to defeat part of the purpose of the suspension, but I've never seen this done.
What is the consensus for best way to raise the front to be level?
2000 F-150 XLT Sport
Silver
4 door Supercab, Short Bed (Only way to fit in the garage)
17" Sport Wheels with BFG tires
4.6l V8, Auto Transmission (First one in 20 years)
In-Dash Single CD Player
Hopes and Dreams:
Spray-in Bedliner
K&N Filter
WMS Velocity Tube
FlowMaster Exhaust
Nerf Bars
Old Feb 28, 2000 | 04:42 PM
Don C's Avatar
Post
Hi Y2kXLTSport
I think all 4x2 trucks use coil springs, thats why it is easier to lower the rear with shackles to even it out.
1999 F150 4x4 4.6V8 regcab/shortbed
Oxford White with Wedgewood Blue two tone, with Blue Captains chairs
Bassani Cat Back, Superchip,Modified intake with modified K&N filter.
Centerline Saber rims 17x8" with Firestone GTA 275/60hr-17 tires.
Old Feb 28, 2000 | 04:50 PM
Post
The problem is I really do not want to lower the truck at all. Would rather leave it as is than lower the rear.
Old Feb 28, 2000 | 05:43 PM
Loser1's Avatar
Post
Y2KXLTSport,
A fellow member, CCLA, used 1" coil spacers. https://www.f150online.com/f150board...ML/000382.html
Old Feb 28, 2000 | 11:58 PM
TexasAg's Avatar
Post
Y2kXLTSport-
Most people around here say the 3" spindles are the best way to go with the 2WDs. I ordered mine last week and should get them next Tuesday. The spindles in the front plus a 1" block or add-a-leaf in the rear will level the pickup.
I agree with you, I wanted to raise the front end to level it and not lower the rear. I hit enough crap with the front end as it is. Good luck.
Old Feb 29, 2000 | 01:08 AM
woody24's Avatar
Post
y2kxltsport, I hate to preach the Fabtech company but That's the company I plan to use for my truck. They have a number of options to choose from. Sounds like their 2" basic system would work for you. It's a new coil and should lift your truck high enough for 285's, if that's what your looking for. email at fabtechmotorsports.com good luck!
Old Feb 29, 2000 | 09:40 AM
ccla's Avatar
Talking
I like the Spindels + a 1" block in the rear. As Loser said I do have 1" coil spacers but that's in addition to the spindles, and a body lift. The Spacers were added to help clear the 35's
98 F150 2WD,Bright Red, Regular Cab, 4.2, 3.55, 5 Speed, Superchip, 2 Superchip Decals (I Think They Add 5 HP Each), 3 Inch Bullseye Lift Spindles, 3" Body Lift, 1" Coil Spacers, 3" Blocks In Rear,Manik Grill Guard,Nerf Bars, Vent Visors,Air Box Mod, Fog Lights Mounted In Front Air Dam ,4 Kc DayLighters, Back Up Lights, Alpine CD Player, 2 Kenwood Amps, 10 Inch MTX Blue Thunder SubWoofer, Tinted Windows. 35" BFGOODRICH ALL TERRAIN KO'S Mounted on 16.5x9.75 American Racing Baja Rims
..........."IF YOU CAN'T STOP, SMILE AS YOU GO UNDER"...........
'00 Toyota Celica GT( Wife's Car )
Pics @ http://www.angelfire.com/la2/ccla/
[This message has been edited by ccla (edited 02-29-2000).]
Old Mar 1, 2000 | 08:51 AM
Chris Thomas's Avatar
Cool
I don't think the 4x2 models even have torsion bars... Can someone back me up on this? Coil springs would be the better way to go I think and they are not nearly as expensive as the spindles.
Chris Thomas
1998 F-150XLT Flareside STX Sport Package, 4.6L Auto 3.55 Oxford White/Gray interior, Factory Anti-theft system
Picture: http://216.147.104.171/Y2K/members/ChrisT/christ1a.jpg
Homepage: Chris & Brandi's Universe
Mods: A.R.E. Decklid/Oxford White with gray fabric liner, K&N filter with Airbox Mod (removed silencer), Lowered 3" front/5" rear, Tinted Windows, GTS sloted taillight covers (painted Oxford white to match), Removed STX stickers
Audio: Kenwood Truck speakers with 10" woofers, Rockford Fosgate and Alpine Amps, Ford 10 disk CD changer
Future Mods: 20" rims and tires, True duals with Supertrap tunable mufflers, Superchip, Supercharger, Jacobs Ignition, and whatever else I can think of!!!
Old Mar 1, 2000 | 09:42 PM
brew1891's Avatar
Post
Correct, 2wd's do not have torsion bars. Most members of the board agree that taller springs arent worth it due to ride quality, alignment, etc. Spindles are the way to go if you want it right. Maybe try a spacer in front and see how that works for you. If you are mechanically inclined, installation and removal isnt that hard and it may solve the leveling problem fairly painlessly. There was a prior thread where a few members were complaining about using taller springs. They just dont seem worth it.
My 2 cents
Old Mar 1, 2000 | 10:49 PM
veloci's Avatar
Thumbs up
y2kxltsport,
I agree with brew1891. If you are going to lift the truck, you must go with the spindles. I went with the coils and i regreted it, i was the biggest mistake i have made in a long time. It will make you ride stiff and the aligment off. In the long run you are better off with the spindles. I got mine from 4wheel parts wholesellers for about $415.00 a set plus the 2" blocks for the rear for $50.00. When you call them ask for the pro comp spindles which are bulleyes. You get a better price and do not ask me why. I hope this helps.
Black 99 xlt sc flairside,4.6 2w.d.,50 series flowmaster catback,
superchip,
rsx shocks,
hellwig sway bar,
3" lift procomp spindles,A/R PHYTHON,285/75/16 A/T B.F,2' BLOCKS REAR.
FUTURE MODS: driving lights, LS AND 4.10 GEARS.
