Sponsored by: CARiD
Suspension lift question (,,again)
Old Feb 25, 2000 | 08:35 AM
4rdfan's Avatar
Question Suspension lift question (,,again)
Is there any suspension lift kits on the market today that will lift a 99 F-150sc 4x4 high enough to fit 35/16.5 BFG-AT's without any cutting of the frame or alterations that cannot be changed back?
I don't mind the "very involved" lift kits as long as they can be put back to factory spec. I am also looking for as close to stock ride as possible.
I lease & want to take the kit/tires on to the next truck.
Any suggestions, thanks,,,4rdfan
1999, F-150, XLT, SC, SB, 4X4, ORP, 5.4, Auto, 3:73, Dark Blue/ Blue Captain Chairs, Full Jam, AirRaid, Bed Cover, Bed Mat, White Signal lights.
Old Feb 25, 2000 | 09:33 AM
Squanto804's Avatar
Smile
4rdfan, 35"s will fit with a 4 inch lift.Any of the big name companies(Superlift,Rancho,Trailmaster,Pro-Comp) make 4 inch lifts that can be put back to stock. It would be alot of work but could be done. I have a Trailmaster and there was no cuting or welding and because everything is dropped 4", there really is no difference in ride, If you use add a leafs in the rear, which some of the kits come with along with the shocks , it will ride a little rougher . I used blocks instead and some good aftermarket shocks, and mine rides as good or better than stock. Little top heavy around tight turns but not bad.
Might want to consider a body lift but you will probably get a little rubbing but is not as $$$ as a susp. lift and easier to return to stock. Just remember that with the bigger tires you will lose alot of power and throws gearing out of wack, so a gear change helps return power curve back to stock.
Good Luck
97 F-150 Black, 4x4 XLT ext.cab,sb,offroad pack.
4" Susp. lift, 3" body
4.56 gears w/LS,
Flowmaster 50 Series w/ duals out rear
36x14.5x16.5 Super Swampers TSL Radials,
16.5x9.75 Weld Scorpio V wheels,
Pre-Runner Bumper w/KC Lights Daylights,
Westin nerf bars,
Pro-Comp Front Skid Plate(not yet installed),
Summit Aluminum Diff cover,
Rancho 9000's and remote,
Lift Lips,
Lighted FORD logo,
K&N Filter,
Superchip,
TransGo Shift kit,
Bug shield,Tinted windows
Sony ES head unit,Sony ES changer,MTX Thunderform sub,Boston Acoustic Pro-Series up front, Polk in rear,PPI & Coustic Amps,Alpine Alarm
Check it out at:
http://members.aol.com/squanto804/scottwebpage.html
[This message has been edited by Squanto804 (edited 02-25-2000).]
