Sponsored by: CARiD
Off-Road-Package
Old Feb 22, 2000 | 11:04 PM
Highground's Avatar
Question Off-Road-Package
I have a 97 F150-4x4-ExCab-4.6Lv8. I have read that Fords off-road-pkg comes with h/d shocks, skid plates and decals. I recently replaced my stock 16" wheels with stock 17" w/265-70-17 but I still don't sit as high as the off-road-pkg trucks. What else do I need to do w/o purchasing an aftermarket lift kit? Does it have something to do with the torsion bars? Any suggestions would help.
Old Feb 23, 2000 | 10:42 AM
cphilip's Avatar
Post
Mine sits just as high with the 16 inch wheels but I put 265/75 R16's on it to get the same height(31.6 inches). I did put better shocks on but I do not think that gave me any lift. I don't know what to tell you. You have everything you need other than the shocks. What truck are you using to compair with? Are you sure it's stock? Front Torsion bars are at the same adjustment?
97 F-150 SC Lariat, Styleside, White over Gold, 4.6L (Windsor), Automatic, 3.55 rear end, electronic 4X4, w/ every option of Lariat and ORP packages except the 17" wheels (I even got the OR decals now!) MOD's so far: K&N air box mod, Gibson Super Truck, clear Bugflector II, Leer TSC 600 hard cover, Bridgestone Dueler OWL ATP 265/75 R-16's, TrailMaster Invader N7 shocks, Smittybilt step bars, Ford moulded mud guards, "White-white" head lamps, Cloud Rider Design's SS Grill and bumper opening, Bosch Platinum + 4's, Hayden 30K+ Tranny Cooler,Class III Reece load distributing hitch system, full wiring including trailer battery charging system, Escort Sensor II Brake controller, Superchip
Old Feb 23, 2000 | 06:31 PM
Highground's Avatar
Post
hey cphilip, thanks for the reply. I usually measure the window height with a tape and the orp seems about an inch taller. Maybe its just my imagination. You are right though, the 17" wheels/tires are not any taller than the 16" w/265-70-16 but they are .5" wider and look a bit more aggressive.
Old Feb 24, 2000 | 09:09 AM
cphilip's Avatar
Post
Only the wheel is wider not the tires but I do like that saw blade type. Just hard to find tires and they are not cheap even then. Look into the torsion bar if you are measuring near the front area. His might be cranked up a little more than yours.
Old Feb 24, 2000 | 01:16 PM
Robs4X4's Avatar
Post
Hey Highground, I put 265/75x16's on my 97', and I think it sits just as high as the "Off Road" stickered 4x's. I would love to find out if the skid plates are available aftermarket.
Thanks,
Rob
1997 F150 XLT Ext. Cab, Green, 4.6 v8, 4x4, A/EOD, 3.55, K&N w/Low-Buck Airbox Modification, Splitfire Triple Platinum Plugs, Bedliner, 265/75/16 Dunlop Radial Rover RV's.
