Getting Bilstein Shocks! What Else Do I Need?
Ok I am planning on getting some Bilstein shocks to replace my old factory shocks. I need new shocks bad and I figure I might as well just get the good stuff
Anyways I know I need 4 shocks. But what else will I need? Are there any bushings or anyhting that should be replaced at the same time or are they just a bolt-on affair? What all do I need besides the shocks?
Thanks!
1993 Ford F-150
Kustom Kreations Package
2WD, 5.0 (302), AOD, 3.55
K&N Drop In, Superchip, Dual 2.25" Exhaust & Pirelli Scorpion Zeros!
Eclipse CD Player, Eclipse 8-CD Changer, Eclipse Amp, Clarion front speakers, 8" Boston Acoustics Subwoofer
Future Mods: New Shocks and TransGO Shift Kit
Thanks!
1993 Ford F-150
New bushings should come with the shocks. They will probably be much stiffer rubber or made of urethane. A big part of why the aftermarket shocks reduce body roll is because of the stiffer bushings. Shocks are an easy bolt on, everything you need is in the box.
1999 XLT S/C, 4.2 V-6, auto, 3.55 rear, dark torreador red/harvest gold, bed liner, Sony 10 disc CD, Edelbrock IAS, K&N filter, Superchip
[This message has been edited by dirt bike dave (edited 01-25-2000).]
Wait just a minute there! Not so fast. Of course you will now need a Brush bar, Winch, Bigger tires, a Super chip, An exhaust system, and a .....
97 F-150 SC Lariat, Styleside, White over Gold, 4.6L (Windsor), Automatic, 3.55 rear end, electronic 4X4, w/ every option of Lariat and ORP packages except the 17" wheels (I even got the OR decals now!) Almost completed the Towing Pkg. options, MOD's so far: K&N air box mod, Gibson Super Truck, clear Bugflector II, Leer TSC 600 hard cover, Bridgestone Dueler OWL ATP 265/75 R-16's, TrailMaster Invader N7 shocks, Smittybilt step bars, Ford moulded mud guards, "White-white" head lamps, Cloud Rider Design's SS Grill and bumper opening, Bosch Platinum + 4's, Hayden 30K+ Tranny Cooler, Superchip on the way!
hey just buy the ROUSH RACING suspention and get it over with........they come with BILSTIENS and the suspention is engineered for handling ,not just a dropped look!!!
pacific green 97 f150 4.6l..reg cab flareside 150XLT ,ROUSH suspention down 3 fr and3.5rear with BILSTIEN shocks,3.55LS,snug lid,carpeted bed, painted tailight accents,4x4 grill &bumper,k&n,SUPERCHIP(THANX MIKE),ram air kit,valvoline synthetic,accel super stock wires,platinum plus4 plugs,flow master muff,blue halogen bulbs, speed-glo dash,carbon fiber gauge accent,..."#6 sticker!!!!"
STEREO:eclipse head unit ,boston seperates ,orion amp, pioneer amp,2-orion 12's,custom box by me!,sony adjustable crossover,1 farad cap&way to many cd's
How about a set of Addco sway bars? Take advantage of the new shocks and Pirellis by flattening out the handling a bit.
Addco's site is http://www.addco.net/
Always do sway bars in pairs. If you stiffen just the front the truck will understeer (push) even more than it does now. If you stiffen just the rear it will tend to oversteer (get loose) more than you want it to. Changing both bars to a slightly stiffer front plus a rear will take out just a little of the push you now have and get rid of a whole lot of body roll. Get the optional urethane bushings, they're worth it.
Joshman - no, I haven't taken any digital pictures of my truck. Maybe I'll borrow my dad's digital camera and take a few shots. I think it is a good color combo (my wife helped be pick), but it is all stock as far as paint & ride height. Around these parts, I occassioinally see the same colors, so it must be a pretty popular choice.
In reply to the Bilsteins. Just put a set on my 1999 F250 4X4 (Light Duty). They are fantastic! Way better ride, much easier to drive (control/handling) - not too stiff. Use to have KYBs on a different truck which seemed stiffer.
Installation (01/23/00): I installed the Bilsteins with the provided bushings - upper & lower doughnuts for the top (threaded) end. Ended up taking off the provided bushings and went with (reused) the stock Ford Bushings. Here's why: The Ford Bushings fit much much better in the top mounting holes - both front & rear. The Bilstein bushings seemed to "slip into" the large mounting holes in the rear causing the top and bottom metal bushing compression plates (the large washers that sandwich the bushings on both sides of the frame) bottom out on the frame.
Recommend re-using (or get new) the ford bushings. The lower piece of the upper bushing set has a raised cone that fits into the top cupped piece (both front & rear) - a much better design that the Bilstein design.
NOTE: The bottom Ford bushing just slides off the shock. Use the Bilstein washer on the bottom.
The top Ford bushing has the nut/washer as a single piece. No need to use the Bilstein washer here. The nut threads are identical for the Ford shock & Bilsteins - the Ford top piece (washer/bushing) threads onto the Bilstein.
Note
Note
