Rancho RS9000X, set of 4 ($210) Free Shipping
Feeling like I been rode hard and put up wet........I appreciate all the comments and information. I suppose if I knew all the answers, I wouldn't be on this board.
Thought I knew all the answers once.....then they went and changed the questions on me.
Originally posted by Viejo4X4
Well now....got a question of sorts. Talked to a guy the other night who is a regional sales manager for Car Quest Auto Parts. He tells me that there are only 2 shock absorber "manufacturers", and that all the shocks are made by these guys and all other "brands" just put their name on them. He tells me that Gabriel and Monroe are the manufacturers. He said that the Rancho RSX and the Gabriel Gas Ryder LT are basically the same shock. If this is the case, the Gabriels have the price of Ranchos beat by about 40%. I'm currently looking around for some new shocks for my truck, as the tires have about 10,000 miles on them and are looking pretty ragged, and the ride is deteriorating pretty fast.
Not trying to start a war here, just thought this was an interesting point.
Unlike other shock absorbers produced in the Monroe plant, the Rancho RS5000 and 9000X shocks are assembled using components designed and specified by Rancho engineers.
Ok, I just read this whole thread and was not thinking about putting new shocks on my truck, but now I want to, just because I read the thread and read nothing but good about the shocks. Except, I'm new to all this, what do these shocks do for the truck, just make it ride better. Any height diff. And just how easy is it to replace?? Thanks for the help.
Well, first let me say I have no idea if there is only two shock manufactures or not. However I can tell you that if there were only two manufactures that make all the different shocks except with different labels, or colors etc that they are NOT the same.
The different types of shocks will have different qualities of material, different manufacturing techniques etc. Don’t for a minute assume that just because there are “two” manufactures that there is only two types of shocks on the market but advertised as many different ones with different prices.
It is the same for tire manufactures that produce many different “brands” of tires that may come from the same manufacture. These different “brands” of tires will have various different qualities of materials used to make them. Basically the cheaper the price, the cheaper the quality of material and/or process used to produced, same as with shocks.
It comes down to the old saying, you get what you pay for. Go with a cheap shock for $20 and it will not last as long, nor have the same quality as a $40, $60 shock.
Pretty easy to install. Took me about 2 hours for all 4, but next time it should be less.
A better shock gives the truck more stability without adding wheel bounce. The adjustable RS9000x allows you to control that stability. The highest setting is a bit of a stiff ride, more like you would experience in a sports car.
Originally posted by signal5065
Well I finally have my 9000x on my truck still playing with the adjustments. will let you know where I end up
Doug
Well I finally have my 9000x on my truck still playing with the adjustments. will let you know where I end upDoug
It's easy to change, it's just a dial that turns 360*. The tough part is that you have to get your hand on the shock to change it.
For the rears I lay under the back to the truck and reach out to each shock. It is on the bottom front of the shock.
For the front I can reach over the tire and turn each one. This works good when the tires are clean, but go through some mud and setting them back will be a problem until you clean up the tires.
I suppose it could be done in a minute, but I take more like two minutes.
