Sponsored by: CARiD
steering wander
Old Oct 13, 1999 | 03:10 PM
ccla's Avatar
Post
I think you're talking about a steering stabalizer. Those are to keep your tires from moving back and fourth while 4wheeling. You have what sounds like wandering tires. I think changing the brand or model tire might help.
98 F150 2WD,Bright Red, Regular Cab, 4.2, 3.55, 5 Speed, Superchip, 2 Superchip Decals (I Think They Add 5 HP Each), 3 Inch Bullseye Lift Spindles, Manik Grill Guard,Nerf Bars, Vent Visors, Fog Lights Mounted In Front Air Dam ,2 Kc DayLighters, Back Up Lights, Alpine CD Player, 2 Kenwood Amps, 10 Inch MTX Blue Thunder SubWoofer, Tinted Windows. And Coming Soon: 3 Inch Body Lift Kit, 16.5 x 9.75 American Racing Baja Wheels Wrapped With 33x12.5x16.5 BFG All Terrains
Old Oct 14, 1999 | 12:21 AM
93excab4x4's Avatar
Unhappy steering wander
While driving on almost any road i've noticed that i have to chase the steering slightly, almost like understeer. I have heard that mounting a shock on the steering rack will help? This is not severe but just a nuisance.
[This message has been edited by 93excab4x4 (edited 10-14-1999).]
Old Oct 14, 1999 | 01:16 AM
sugarman's Avatar
Registered User
Exclamation
Well if you have a 93 like your nick suggests and you do much off roading better check that U-joint on the stearing column, tie rod ends and ball joints.
By the way how are your tires wearing?
I had a 90 before I totalled it and changed all of the above and I-beam bushings except for the u-joint at 75,000 miles all needed changed in the worst kind of way. Although it had 33's and went out in the woods every weekend and was beat to death!
99 F-150 XLT Sport, Black 4x4 4.6L , 3.55 LS,Manual Tranny, K&N air filter, No Muff Exaust system,.999 tuned TPS,Pioneer CD Player,Pioneer GM-X332 Amp,8" Rockford Fosgate Punches, Custom(self done)pinstriping,Wrap around bugdeflecter
Old Oct 14, 1999 | 02:09 PM
cloaker's Avatar
Post
a steering stabilizer will reduce your steering wheel jerking around when your front tires hit bumps, or water. That is when one wheel hits first, then the other, usually your steering jerks around, the bar reduces that. I had one in my jeep commanche...let me tell yah, when one tire hits a deep rut of water, by the time the back tire on the same side hits it, the entire vehicle would slide over a couple inches..that was scary!
David
'99 F150 XLT SC, STYLESIDE
4X4 ORP 5.4L, AUTOMATIC,
139wb, Rhino, K&N,
BugGuard, RainGuards
Superchip
Old Oct 14, 1999 | 02:36 PM
93excab4x4's Avatar
Thumbs up
Thanks for all the input. I'll be looking into changing a few things
93' 150 excab
302 E4OD
8.8 4.10 rear, dana fr diff
more towing then 4x
Old Oct 14, 1999 | 07:55 PM
dirt bike dave's Avatar
Post
You may also want to have your alignment checked. My friend with a '94 claims it drives much better (less wander on the highway) with the caster set at the maximum allowed in the specs. You'll have to ask the alignment shop to set it up this way.
Old Oct 15, 1999 | 12:26 AM
93excab4x4's Avatar
Post
Tires (10.5x31)are rotated every 5k miles wear is normal. I have the 8.8 rearend and recently it gernaded. I went to a rearend parts house/garage and there were a couple dead units in the dumpster. I'm guessing that its not a real choice setup. Anyway I'm looking into moding the E4od trans I do some towing and it works fine for that but running empty I don't like the shifting. Baumann engineering is spouting great things ever heard anything regarding them.
