Sponsored by: CARiD
2'' lift
Old Jul 24, 1999 | 02:06 AM
veloci's Avatar
Question 2'' lift
i have a 3'' spindle lift in my truck and i want to add 2'' more. i have seen a few members with coil spring lift, can anyone tell me how much stiffer your ride turned. i do not want ruin my nice comfortable ride. my truck is 2wd and i am looking at the fabtech 2"leveling kit. thank you.
99 xlt sc,4.6 2w.d.,gibson catback,superchip,airaid,rsx shocks,hellwig sway bar(soon to be removed),3" front lift.
Old Jul 24, 1999 | 09:55 AM
T Ellenberger's Avatar
Post
Where did you get the spindle lift and how much? Did you do the install or have it done?
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, 4.6, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs
Old Jul 24, 1999 | 11:23 AM
veloci's Avatar
Post
I bought them from 4wheel wholesellers and they were about 540.00 including tax. i did install them myself and it took me about 8 hrs. they wanted 315.00 for installation so that is why i did it myself. it is not that hard, just make sure you have all the tools before you start the job.
Old Jul 25, 1999 | 09:55 PM
No1Truck's Avatar
Post
I would not recommend the leveling kit. It may top out your upper A-arms, making it almost impossible to adjust camber to the correct specs. The leveling kit works only with the supercab. Even with the supercab, I would recommend doing it right with the 3 1/2" lift. I believe it will save you some alignment troubles in the long run. The upper A-arms on my Fabtech lift are beefy and, in my opinion, are worth the money.
Old Jul 27, 1999 | 11:40 PM
No1Truck's Avatar
Exclamation
One more thing. My ride did firm up with the 3 1/2 inch lift-now with the truck unloaded, the front and rear springs feel about the same stiffness. It isn't unacceptably harsh, however. It just gives you a little more feel of the road surface. Oh well- If I had wanted a Cadillac, I would have bought one.
Old Jul 28, 1999 | 01:32 AM
veloci's Avatar
Thumbs up
thank you for all the feedback. now, how much was the 31/2 lift including installation?
