Sponsored by: CARiD
Leveling Screw ?
Old Feb 2, 2003 | 05:45 PM
rbraughn's Avatar
Question Leveling Screw ?
I know most people drop the rear end to level the 2wd Screw, But I was thinking instead I would like to raise the front so I can put a little larger tires for the Deer Lease.
What is the best way to do this ? And what are the pro's and cons if any.
Old Feb 2, 2003 | 08:26 PM
rbraughn's Avatar
*Sniff* Sniff*
Do I smell or sumthin!!!
Come on guys I know someone out there has some advice for me.
Old Feb 2, 2003 | 09:44 PM
SCrew-EC's Avatar
If it's 2wd...Daystar makes coil spring spacers. Easy install.
If it's 4wd...the least expensive thing is crank the torsion bars up a bit! Hope that helps.
L8r
Old Feb 2, 2003 | 11:07 PM
rbraughn's Avatar
Thanks,
Are those the bushings that go under the coils, if so do you have to get an alignment or does it affect the ride quality?
