Sponsored by: CARiD
Lowered 4wd
Old Jan 11, 2003 | 11:20 AM
American Badass's Avatar
Lowered 4wd
Is it possible to lower a f-150 with 4wd? if so has anyone here done it?
Old Jan 11, 2003 | 11:24 AM
jwrape's Avatar
I know it is possible. I don't know anyone that has done, but I have seen it done.
Good Luck!
Old Jan 13, 2003 | 12:39 AM
Jimmy Lee's Avatar
Its very possible to lower a 4x4......seen it done many times....actually is quite practical!! but if i were you i would go up man!!....lift it then it will be a chick magnet!!!!....but even if you do lower it remember go big!!! at least 20's anything less looks fugly!!!!!!
I thinkDJM makes a 4/6 drop for the 4x's
JJ
Old Jan 13, 2003 | 05:37 AM
Magnum88C's Avatar
Originally posted by Jimmy Lee
Its very possible to lower a 4x4......seen it done many times....actually is quite practical!! but if i were you i would go up man!!....lift it then it will be a chick magnet JJ
Not to mention with a lift you have an excuse to put your hand on certain posterior parts when helping said chick into the vehilce. Ususally you can avoid a good slap with this method. Unless you're into that, in which case, simply pat said area once said chick is in said lifted truck, and you will get a good slap. Or, you might get an 8" lift of your own when said chick kicks said pervert (Read normal heterosexual male) in the nuts!
Magnum
Old Jan 13, 2003 | 02:04 PM
I was thinking of having Attitude Performance placing a 6" suspension lift, 3" body lift, 38" swampers on some Weld wheels, new gear ratio (4.56), speedometer calibration. The only problem is the price, $7000. That just seems kind of high, so i might just leave what i have alone and place SVT Cobra parts onto my engine, they seem to fit nicely . Then i will go interior. What do you people think?
Old Jan 16, 2003 | 03:25 PM
Jimmy Lee's Avatar
What ever floats your boat!! Id lift
JJ
