Sponsored by: CARiD
Pre Runnin
Old Jan 3, 2003 | 02:16 PM
EM02supercrew's Avatar
Pre Runnin
Ok I am going to try this one again.
I am looking for anyone out thee who has found a cheaper alternative to FabTech's 2wd lift kits.
I am hoping to be able to put 35's on my truck so let me know how you accomplished this task.
Also what other mods have you all done to complement your lift and tires?-
EM
Old Jan 3, 2003 | 04:13 PM
wandell's Avatar
If you want a inexpensive lift for a 4x2 Screw, I would suggest the following. First, add a 3 inch body lift. That should be around $130 or so. Then you can add 2 inch Daystar coil spring spacers for around $50 or so, or 2" lift coils. You will need to have the front end aligned because of the spacers and you will want to add gap guards with the body lift (around $50-$60). This will give you 5 inches of lift in the front and 3 in the back, which should basically cause the truck to sit level. This should put you at the same, or slightly taller ride height as a stock 4x4 with its torsion bars cranked all the way up which should allow you to fit a 305/70-16 (33's) on a 16x10 inch rim. You may be able to fit 315/75's (35's) on a 16x8 rim but I'm not positive. If you add 3" lifted spindles ($300-$400?), you should fit 35's with no problem.
Old Jan 5, 2003 | 07:08 AM
ScrewFly's Avatar
Registered User
Sounds like you have the same idea I do.
I'm going to go with a small lift, like 3-5, possibly Fabtech, or RCD.
I'm also going with the fiberglass fenders all the way around to give me more clearance for 35's.
I'm not sure what is a less expensive option, but the fenders are about $800 for all four, and a 3 in lift for it can't be that much, and you'll fit 35's in with no prob.
HTH
Old Jan 10, 2003 | 05:58 PM
Captain_Nemo's Avatar
Try AIM , they have the best price on lift kits. I've had mine on for 2 years with absolutely no trouble.The quality is as good as any of the other brands as far as I can see they just don't have the inflated price.
Old Jan 12, 2003 | 02:29 PM
cmeflyn's Avatar
Pro Comps 3" spindle lift cost me $695 installed (on My 01 F150 Supercrew) and you will have a smooth factory ride!!!! I fitted 285/75/16 BFG AT KO's with no rubbing & no trimming on stock rims!
