SuperCrew
celcius to Farenheit
Old Dec 2, 2002 | 04:35 PM
softgenious's Avatar
Stupid question? Do any of you know how to change the Electronic air temp reading on a Super Crew heater/AC from celcius to farenheit. I have a sunroof , so my inside and outside temp control is on the heater/ac control...It is not in the manual and the dealer forgot to set it up.
Old Dec 2, 2002 | 10:59 PM
Marc STewart's Avatar
Stupid question? Stupid answer: Take it back to the dealer and make him change it at no charge!
Old Dec 2, 2002 | 11:37 PM
Wino's Avatar
press max a/c and the defrost button at same time and hold for about one second.
Old Dec 3, 2002 | 09:32 AM
Wino,
You are the MAN... It would be way to easy to go back to the dealer. I
Old Dec 3, 2002 | 04:58 PM
Thanks Wino it worked...
Old Jan 8, 2003 | 08:00 PM
rvholland's Avatar
Thought I was going crazy looking for the instructions on how to change the temp display from C to F. Glad to see I wasn't the only one and that someone had the info needed. Thanks!
Old Mar 20, 2006 | 12:19 AM
candrusiak's Avatar
I think I have a unique problem. On my 2004 screw XLT the exterior temp display indicates that the temperature is in Celcuis but the number displayed is clearly in imperial units. For example when driving on friday the weather report on the radio indicated that it was 0c outside but the display indicated 32c which is obviously incorrect but would be correct for degrees F. Can the disply be changed or reset?
Any suggestions?
