'02 SuperCrew Bolt Pattern?
Did a quick search and only came up with a post dated from 2000. I need to verify that the 5 x 135mm bolt pattern is what the '02 SuperCrew's use. Thanks.
Dude,
Here's the detailed pages you need.
F150 Detailed Specs
navigate to the tire and wheel section and you'll find it there. Actually this info should be listed in many places, this is one good source for future reference though.
If you would have done a search for "detailed specs" or "F150 specs" you should've come up with several finds including the one below:
'99-'03 F150 Specs, Towing Guides, Owner's Manuals & VIN
Looks to me like the bolt circle is listed as 5.3" which converts very close to 135mm and a fraction more. Most definately 5 lugs is correct unless you've got a 7,700 lb payload package and then there are 7 lugs and possibly a different bolt circle too.
Later,
~DM~
F150 Detailed Specs
Later,
~DM~
The bolt pattern IS 5X135 and it doesn't convert to anything other than 5X135. There is NO standard bolt pattern that converts to metric, They are completely different and don't let anyone tell you otherwise. The guy at the tire shop tried to tell me that it converted over "very close" to a 5X5 1/2. BS!!
