SuperCrew
Loose bed?
Old Oct 7, 2002 | 01:50 PM
matteo's Avatar
Loose bed?
This weekend I was loading some motor cycles in back when I saw the bed move a little.
I can go to the drivers side front part of the bed and lift it about 1/4" I took a quick look under the truck to see if I could find anything obvious, but no luck.
Anyone else experience this?
Old Oct 7, 2002 | 05:21 PM
ZJumper's Avatar
Probably just a loose bolt which secures the bed to the frame. Have you tried to snug down the bed bolts?
Old Oct 7, 2002 | 09:05 PM
DAVEMAN's Avatar
Guys,
I've noticed that mine does this too, I think it's normal and it's just the rubber cushions that the bed rests on. I doubt the mounting screws are loose, but if you have time and the proper tools, check it out and see.
I notice mine moves a good bit with I haul concrete in the back and when I'm unloading it and placing it on the tail gate, seems to move at least a half inch or more. I had a '00 Super Cab and it did the exact same thing and so did my '99.
My 2 cents.
~DM~
