SuperCrew
what kind of grease??
Old Sep 5, 2002 | 09:10 PM
grishfish's Avatar
I'm a bit of a newby to this whole maintenance thing, so help me out. What kind of grease should I be using to grease the fittings. I don't know what kind of grease is in there now (whatever Ford uses). Is it OK to mix different greases (normal and synthetic)? Since I'll be using this on a jet ski as well, I want to use marine grade grease. Will that still be OK for the truck as well? What kinds would you recommend? Thanks!!
/Marcus
Old Sep 6, 2002 | 02:19 AM
Wino's Avatar
i travel in snow as much as i can. and i use the marine grease. no prob's here. there are only two fittings but i grease them every time. i change the oil.
Old Sep 6, 2002 | 07:23 AM
S'CrewLoose's Avatar
Wino,
Two grease fitting isn't alot.......lol.......I'm filling the rubber boots with grease using a syringe and needle..I'm not sure its getting all the way into the ball joint but I figure it can only help.
Old Sep 6, 2002 | 10:23 AM
grishfish's Avatar
fyi
Here was a good reference I found.
http://www.lubrizol.com/GreaseRefere...ect/select.htm
